Trans Temp Gauge, TH350
Old 03-10-2011, 01:51 PM
BlackBirds's Avatar
Default Trans Temp Gauge, TH350
Where are you guys putting the temperature sensor for for a transmission temperature gauge on TH350's? I read that on the 4L60E's they just screw into the inspection port, but what about on the TH350's?
Thanks
Old 03-10-2011, 02:13 PM
Boman6760's Avatar
Mine had a spot in the case but I welded a bung in the pan anyway. With my cooler I show 160 normal driving. 180 Playing a little. Still on a break in so I haven't been to hard on it as of now. Thats also with cooler in radiator then to B&M cooler.
Old 03-10-2011, 02:50 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Got mine in the pan
Old 03-11-2011, 10:59 PM
BlackBirds's Avatar
hm...is there any way to tie into the lines? I'd rather not drill into the pan, its too pretty
Old 03-12-2011, 02:57 AM
Boman6760's Avatar
I tied into the lines on my Jeep. Used a brass T and compression fittings. Thing still seems to drip a little no matter what though. Honestly I prefer it in the pan myself over the two.
Old 03-12-2011, 10:14 AM
BlackBirds's Avatar
ok, thanks for the information guys
Quick Reply: Trans Temp Gauge, TH350
