can i run a 295 on my factory 16 inch wheels
im looking to put some 295s on my factory z28 wheels for the track,from the factorty they where 16/245 any help would be greatly appreciated
OP are you looking at the 295/50/16 MT drag radials? If so they will fit just fine...per MT's website it says they fit 8"-10" wheels. Plenty of people have run them without any issues.
I've personally mounted 295/50/15s on 8 inch wheels with no issues before so being an inch taller shouldn't make much difference if any. I believe the reason a 295/50 will fit on an 8" rim and be ok and a 315/35 wont fit on a 9" rim is because the 295/50 has a taller sidewall that has more give and flex.
You can fit a size 10 foot in a size 13 shoe as well, doesn't mean it's a good idea. If you did mount a 295 on a 8" wide rim, you wouldn't be utilizing the entire width of the tire tread, however.
Cons:
More expensive tires
Less safe
Not utilizing entire tread
Pros:
It looks cool (to some)
a 295/50 would have the same size sidewall no matter what brand it is The second number in a tire size is the aspect ratio, which indicates sidewall size in a percentage to the first number in the tire size (tire width) so in this case, the sidewall height would be 50% of the width of the tire (295). It won't/shouldn't vary much from brand to brand as the width is measured in millimeters.
Cons:
Less safe
Pros:
ok so im guessing that size will fit? Might get that pair for track and try to find some yoks for street.
so far went to couple places and only tires they get 275/55/16 are 300-500ea............im looking at 150-200 each, maybe 250ea MAX
