Drive by Wire TAC Pedals
Old 03-10-2011, 07:07 PM
Bobby G's Avatar
Default Drive by Wire TAC Pedals
Does anyone know what pedals work with which TAC moduals, I have a 2007 LQ4 and the TAC and Pedal but the Pedal will not work and I can not cut it its plastic
Old 03-10-2011, 08:05 PM
crosstraining's Avatar
https://ls1tech.com/forums/conversio...-assembly.html
https://ls1tech.com/forums/conversio...gas-pedal.html
https://ls1tech.com/forums/conversio...can-i-use.html
Old 03-10-2011, 08:14 PM
Bo185's Avatar
Truck DBW components
The TAC module has two connections, one for the pedal harness..other hooks into main engine harness there are two styles the 9-pin connector the later ones are 6-pin.
TAC modules have to match up to the year range of the PCM AND the throttle body.
03-06 TAC module works with 03-06 truck TB and 03-06 PCM (BLUE/GREEN connectors)
01-02 TAC module works with 01-02 truck TB, 97-04 Vette TB, and 01-02 PCM (BLUE/RED connectors).
03-06 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.
The newer 07 up take a different pedal assembly.
Should look like this
Old 03-10-2011, 08:17 PM
This is some great info. If it is not it needs to be in FAQ
Old 03-06-2013, 01:17 PM
ace32x's Avatar
bumping an old thread. i have an 01 vette ecu im using for my drive by wire ls6 swap. i have a pedal and tac module unit from an 05 5.3L truck. im getting these codes p1120 p1220 p1221 p1515 p1516 p1518 and i have a feeling its pedal and tac module related. judging by the info posted above im going to say that theyre not interchangeable and i need a new set up but thought i would check. also running a nick williams 102 throttle body with the racetronix adapter harness.
Old 03-06-2013, 05:23 PM
LS1Tech Sponsor
psiconversion's Avatar
What does nick Williams say? I'm pretty sure you have to use the vette tac module and pedal with those.
Jon
PSI
Old 03-06-2013, 06:03 PM
ace32x's Avatar
Jon
PSI
i didnt contact them as i figured itd be a better question for the guys who made my harness but theyre kind of iffy on it aswell. basing it off what i can find the 05 truck pedal and tac use a 3 sensor set up as to the 97-04 vettes use a 2 sensor and i have an 01 vette ecu. so im going to overnight a pedal and tac from a vette tomorrow and put that in and see if it solves it. im praying otherwise im out 500 for the pair XD
Old 03-07-2013, 06:37 AM
LS1Tech Sponsor
Keep in mind that the harness between the Truck TAC and Pedal is Different from the Vette TAC and Pedal. Good Luck.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 03-07-2013, 10:44 AM
ace32x's Avatar
Jon
PSI
i believe harness i have is set up for a vette ecu and pedal and tac, its a custom harness from speed scene wiring. but it has the truck plugs on it so im going to have to see where i can source 2 male plugs that match the vette harness tac and pedal plugs
Old 03-07-2013, 11:39 AM
ace32x's Avatar
thanks on giving me a hand and working with me on that connector jon! i would have had you guys make me the harness had i known about you a few months ago!
Old 03-07-2013, 05:09 PM
omc8's Avatar
I need to know what passenger car pedal will work with 2007+ nnbs Silverado ecm and harness ?
Old 03-07-2013, 07:05 PM
LS1Tech Sponsor
Vette pedal will work if it is configured for it.
Jon
PSI
__________________
Ebay Store
Old 03-08-2013, 03:44 PM
Bo185's Avatar
Pretty much any 6 pin one will work as long as its pinned right for that peda.l I would have to look to see if they are all pinned similarly to the GMT900 trucks.
So most the 07-up GM 6 pin plug pedals will work pretty much out of most cars and SUV's.
Lokar makes one that will work as well. But I think its only is the pedal and you have to provide the sensor then remove the plastic pedal and install their metal one on the stock sensor.
Old 03-11-2013, 02:13 PM
omc8's Avatar
I have a pedal from a 2007 Pontiac G6 that I would like to use. And you are right the NNBS truck is 6 pin and G6 pedal is 6 pin , but they are different sensors. Can the G6 be repinned to work with truck ecm .
Old 03-11-2013, 05:56 PM
Bo185's Avatar
Just look at the pinouts and see if they can simply be swapped.
The E38 truck GMT 900 pinouts of pedal plug
ECM Pedal
Pin 36 TN 5-Volt Reference 1 - APP Sensor Pin C
Pin 32 L-BU APP Sensor 2 Signal - APP Sensor Pin B
Pin 23 PU Low Reference - APP Sensor Pin A
Pin 56 WH/BK 5-Volt Reference 2 - APP Sensor Pin D
Pin 29 D-BU APP Sensor 1 Signal - APP Sensor Pin E
Pin 30 BN Low Reference - APP Sensor Pin F
Old 03-12-2013, 09:41 AM
omc8's Avatar
ECM Pedal
Thanks Bo ,
I will check those against the the G6 pins , Can I get those from alldata ?
Old 03-17-2014, 12:46 PM
240sx940's Avatar
03-06 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.[/IMG]
Sorry to revive an old thread but I've looked and can't find the info.
The 97-03 Corvette PCM connectors are (BLUE/RED) and the 04 Corvette PCM plugs are (BLUE/GREEN). Should the 04 Vette TB be with the 03-06 TAC since the PCM has BLUE/GREEN connectors? The reason I ask is I have a engine harness and PCM from an 04 Vette and the connectors are BLUE/GREEN. Thanks.
Old 03-20-2014, 12:24 PM
240sx940's Avatar
No one?
Quick Reply: Drive by Wire TAC Pedals
