Can't get into 1st or reverse??
Old 03-10-2011, 09:56 PM
scv8's Avatar
Default Can't get into 1st or reverse??
Hey guys,
I've got about 40k miles on this clutch and about 12k on the Tick M/C. No issues except high rpm shifting troubles, which the Tick really improved.
All of a sudden I can't get it into 1st or reverse, with the motor on or off. I've bled and re-bled the clutch and have a very firm pedal. There is a screeching sound coming from either the PP or the slave, when the pedal is pushed and released.
I removed the cover and took this pic with the pedal all the way down, to check for release:
How much clearance do I need between the clutch and flywheel? I can't rotate the clutch freely with the pedal depressed.
I've beginning to wonder about the pilot bearing. Any help would be greatly appreciated.
Thank you
Old 03-11-2011, 04:36 AM
Sargeant Sh!tbag's Avatar
I have no trouble putting my car into 1st or reverse even with the clutch not depressed. I dont think your clutch is the issue.
Quick Reply: Can't get into 1st or reverse??
