Can Autozone reset PCM?
Old 02-16-2004, 06:40 PM
Unforgiven1's Avatar
Default Can Autozone reset PCM?
Just wondering...have read bad stuff about pulling the PCM fuses.
Old 02-16-2004, 06:46 PM
slow's Avatar
they can reset the ses light, by deleting your codes, yes.
Ryan
Old 02-16-2004, 06:56 PM
Ryan
Thank you very much...have to go get that done before they close. But a question in regards to that question. LIttle background...SES came on. Had it checked at Autozone. PO412, and PO418 were the codes. After consulting this forum decided to try the AIR fuse. Now, in replacing this fuse should the SES go off automatically or SHOULD the PCM have to be reset?
Thanks in advance,
Justin
Old 02-16-2004, 06:59 PM
slow's Avatar
it should reset itself after a few/many driving cycles i believe. But the code will stay stored in the computer.
I got mine reset by autozone when i had the same problem, so i don't know if it woudl have turned off or not.
Ryan.
Quick Reply: Can Autozone reset PCM?
