Lincolnman
03-11-2011, 09:14 PM
This is a post that I did on the LS1Truck forums first, and then was told to come here.
I will simply cut/rephrase and paste the ideas and responses (from there) for the perusal and response of this forum.
Please feel free to speak up, even to say something stupid.
THIS IS AN ENGINEERING EXERCISE, NOT A BUILD DIARY.
GEN III+ based engine.
Trying to go from idle to red line under full throttle milliseconds faster. So we are not "revving to the moon" just revving to 7,500 REALLY FAST. Think super bike throttle response, or as my father said "a motor that comes on like a die grinder". Let's assume that this is in a stand, so there is no confusion on transmission choices, weight of vehicle or gear ratios. Motor plus flywheel, only accessory drives are water pump, alternator.
Naturally Aspirated
11:1 Compression Ratio
91 octane
7,500 RPM red line
Hydraulic lifters
Aluminum (4 bolt head) block
2 valve heads
Everything else goes.
So - in order to build this there are certain things a person can do in order to achieve faster revs. Lets start out...
1. Shorten stroke - this brings the outermost swing of the crankshaft more in line with the center line of the crankshaft, therefore allowing faster revving at the expense of torque and displacement. This could even be done with the shortest stroke crank available (4.8 crank AFAIK at 83 MM) offset ground to reduce stroke and reciprocating mass simultaneously if using different rods... That or a custom billet crank.
2. Lighten/blueprint/balance reciprocating assembly - including (but not limited to) aluminum flywheel, custom flyweight pistons, aluminum or titanium rods...
3. Reduce reciprocating drag - knife edge and polish crankshaft, add windage scrapers, synthetic lower viscosity oil...
4. Increase air flow - Higher flow from intake, heads, and exhaust. How much flow (if any amount) is too much considering the red line? First things first, ITB (http://www.scienceofspeed.com/sos_resource/FAQs/general/natural_aspiration/ITB_induction/)(Individual Throttle Bodies) intake. Then, in order to increase the flow to the maximum allowed by two valves one needs the largest valves that will fit at the best angle possible. The best I have found is the LSX-DR heads 19166979 (http://www.crateenginedepot.com/stor...P2572C114.aspx) but they are a 6 bolt head. I am told the 6 bolt heads work on the 4 bolt block. I read somewhere that these will flow 430+ CFM intake side (at like .8" lift) and they claim to be good for 900+ NA HP. If they do not work as a 6 bolt head on a 4 bolt block then the next best I see are the LS6 CNC ported 88958665 (http://www.crateenginedepot.com/stor...-P852C114.aspx) though I may have missed something. They claim these are good for 500+ HP and they will flow 304 CFM at .570 lift. NOW - that being said, the former heads require a minimum 4.125" bore whereas the latter heads will fit a stock bottom end of any GEN III+. Keeping that in mind, the increased bore is a good thing in one respect because it allows not only the largest valves but it also prevents shrouding of said valves. If a person uses Darton sleeves the bore can be increased up to 4.200". This would allow maximum valve diameter and either head with minimal valve shrouding. ON THE OTHER HAND, the larger bore requires more air all other things being equal. More air means more time to fill the chamber, which may in turn mean an incomplete fill for a given time (inefficient) or more time for the increased volume. Then at what point (given a de-stroked motor) is the displacement a limiting factor on the given flow numbers. Also keep in mind that the flow numbers given are peak and an average flow will be considerable less. Additionally, the .8" lift of the DR heads is probably unrealistic to clearance. Add to this the chamber differences (50cc for the DR and 65cc for the CNC'd LS6) and we run into changing piston dish to maintain the 11:1 ratio. So the head choice is as clear as mud.
5. Valve train - Assuming that we are using the lightest weight components that we can, then to lighten anything further would be to use smaller valves, allowing weaker springs to limit mechanical losses. Would it make more sense to use the stronger springs to control the valves better? Also, where is the trade off for small, light valves and flow? Roller everything in the valve train seems like a given. Add in a double roller chain. Taking the valve train the the extreme I know that some of the piston engine fighter planes from circa WWII even hollowed the camshafts. Also, there is the possibility of "dimpled" valve on the fluted portion (forgive my lack of proper terminology) as per the "golf ball" effect which has been shown to offer some improvement in flow over standard shaped valves. Dimples and laminar vs turbulent flow. (http://www.ls1tech.com/forums/advanced-engineering-tech/1388976-golf-ball-dimple-technology-air-intakes.html)
6. Accessories - The most aggressive accessory under drive that I know of is 60% - like the ATI 916097. Take this further and put on the smallest alternator available. Is there a MECHANICAL water pump that takes less power to run than others? I have even heard of people under driving their oil pump, though I cannot find that link... Also - what about using a chain to run the accessories? In the case of a motorcycle a chain has less friction losses than a belt, but more intensive maintainence. The fact that is uses less power to transfer power (along with it being narrower and stronger) than a belt is why hogs use belts and (real) sport bikes use chains.
7. Electronic tuning - I know little to nothing about this, so inform me.
THOUGHTS or SUGGESTIONS?
P.S. - I don't need to be told that you can make more power with a 14:1 454 LSX.
Also, sorry about being so long-winded.
RESPONSES
A vacuum pump was suggested, based on the thought that if the crankcase has a vacuum, things will move faster due to the lack of air. I take issue with this logic in two parts:
1. The parasitic loss of running the pump will negate the benefit of not "pushing the crankcase air around"
2. The vacuum pulled will mean that pistons coming down into the crankcase are not pushing air out of the way, but any air pushed by one piston is also pulled to another area by another rising piston simultaneously, so it's "stirring" the air rather than compressing it Admittedly, this "stirring" action occurs too quickly and so compression and decompression will occur, but I do not think that it will be a significant change, albeit perfectly measurable.
I could be wrong on this vacuum pump thing, but I will need more solid evidence than "I saw a guy do that once and he was fast..." Later the comment was made that since the vacuum pump is usually electric "there is no parasitic loss" which is simply false because the electricity to run it isn't free power or we would all just run electric motors tied to alternators. Sound familiar? (http://www.ls1tech.com/forums/advanced-engineering-tech/1285047-self-power-generating-electrical-car.html) There was also mention that pulling vacuum in the crank helps the rings seal better and therefore is an improvement, but I am less certain that will help rev quicker. More power, sure - but I don't see it making things rev quicker, which was the point.
There was some question as to my motive for limiting to 11:1, to which I responded with the following -
"I consider 11:1 to be the threshold for 91 octane compression. More compression generally means more power so I figured it made sense to run all the way up to the maximum practical limit there. Also, higher compression keeps the throttle response snappy so that it doesn't "hang" at higher RPM for an undue period of time. I have also read that you can modify your IAC to help drop RPM quickly after rev up, but I don't know how that works."
I also asked about the "unstreetability" of the 60% "ASA racing" underdrive - under what circumstance would it be useful, then? At what (sustained) RPM is it useful? The response I got talked about idle (where all under drives are negative) and highway RPM as being 2K, which was deemed still too low to get any good out of the alternator or water pump.
Numerous people parroted my initial comments on keeping all moving weight to a minimum.
All contesting and arguing aside I think that it was a good place to start (especially since I was not yet a member here at the time), but now I am looking for more thoughts from new perspectives.
P.S. As far as the block goes I have been thinking Darton sleeved (4.200") or LS7 (4.125"). Any other suggestions are welcome, too.
Naturally Aspirated
91 octane
7,500 RPM red line
Hydraulic lifters
2 valve heads
RESPONSES
