Pontiac GTO 2004-2006 The Modern Goat
I think I may be stupid...(keys)
Old 03-11-2011, 09:29 PM
RedfoxGTO's Avatar
Default I think I may be stupid...(keys)
So here we are, locked out of our GTO because the battery is dead in the silly key... How the hell do I get this thing open so I can change the battery?! Me and several friends have tried everything..
Old 03-11-2011, 10:05 PM
tom's2005gto's Avatar
doesn't the door have a "key hole"
Old 03-11-2011, 10:52 PM
ULTIMATEORANGESS's Avatar
Talking
i was going to say lol.
Old 03-12-2011, 01:32 AM
Now you have my attention
GTOSE's Avatar
I remember having to use the key hole on my buddy's 05, and it worked.
More recently my buddy's 04 just had a dead battery and we literally almost broke the key in the key hole trying to open it, it just wouldn't budge. He ended up jumping it off of the alternator or something along those lines.
Old 03-12-2011, 01:38 AM
-gz-'s Avatar
lmao... please tell me you didnt forget to try the key hole in the door... haha
Old 03-12-2011, 07:03 AM
Rob
Rob's Avatar
If you are talking about the key fob, it isn't supposed to be taken apart. There is a thread over at LS1GTO if you want to try.
Old 03-12-2011, 07:21 AM
Chief Z's Avatar
Right,
If the battery in your keyfob is dead, you have a problem. They are a sealed unit, not ment to be replaced. It charges off the ignition. You will have to get a new (not used!) keyfob off ebay, or god forbid - from the dealership. Then you swap out the key portion by removing the two screws. It will have to be programed to the car, but you can do that yourself. LS1 GTO forums has a thread on this, but it takes 30 minutes to program.
You can always use the key manually, but that is a pita!
Good luck!
Old 03-12-2011, 09:14 AM
the battery in the keyfob is not meant to be serviceable. And it does not recharge from the ignition ring. The only thing that battery does is work the buttons on the fob.
Easy fix, install an after market alarm system.
Old 03-12-2011, 07:21 PM
RedfoxGTO's Avatar
Yeah, they key will NOT open the door for some silly reason, and you have to be kidding me.... I have to replace the entire thing every time it dies? haha... kill me now.... well thank you for the help
Old 03-13-2011, 08:09 AM
csurane24's Avatar
No spare key? Are we safe to assume that you don't have the non ignition key also? If you had that you would get in.
Old 03-13-2011, 07:37 PM
RedfoxGTO's Avatar
Purchased used, it came with one key.
Old 03-13-2011, 07:55 PM
Joeyelbows's Avatar
yea your screwed. Look at it this way while your waiting for your new key fob you know no one will be able to steal your gto.
Old 03-13-2011, 08:16 PM
RedfoxGTO's Avatar
hehehe.... ordered one from dealership.. (ect ect sordid content ect ect)
Old 03-13-2011, 09:13 PM
Joeyelbows's Avatar
if you wanna know how to program it yourself its really easy just time consuming. basically you turn your car on for 30 seconds then off and repeat. i believe you do this 3 times and tada its programmed.
Old 03-13-2011, 11:39 PM
RedfoxGTO's Avatar
eh... and they tried to take advantage of me by saying," wellllllllllll looks like we will have to program that for you! you need special
tools!"
Lucky for me Im not a blonde
Old 03-15-2011, 07:38 AM
Death{AW}'s Avatar
I bet that this key (metal part) and ignition lock is from different GTO. Those cars have lot of problems with ignition lock. I bet somebody just get used from junkyard and did not replace locks in doors.
Old 03-15-2011, 01:36 PM
RedfoxGTO's Avatar
Got my key!!!! VAROOOOM!
Old 03-15-2011, 04:51 PM
i had to mine both reprogrammed. but it was under warranty.
Old 03-15-2011, 05:13 PM
RedfoxGTO's Avatar
Programmed it myself, to be honest I expected much worse...was time consuming though.
Old 03-15-2011, 05:46 PM
Death{AW}'s Avatar
Yea I have to do it to my new keys my original one is almost dead
Quick Reply: I think I may be stupid...(keys)
