B&M electronic shift OR B&M transpak
Old 03-12-2011, 01:15 PM
SoCalCal's Avatar
Default B&M electronic shift OR B&M transpak
Im looking for performance, but if I can save on labor by using the electronic one and get the same performance I would! Anyone know much about electronic shift kits? Thanks.
Cal.
p.s. Oh and the brand doesnt matter to me, The B&M is the ones I came across first.
thanks.
Old 03-12-2011, 04:56 PM
sheikss's Avatar
I would tell you to get a tune if your thinking about buying the electric shift. If your set on a shift kit use the transgo kit.
Old 03-12-2011, 05:12 PM
ULTIMATEORANGESS's Avatar
trans go. b&M is crap.
Old 03-12-2011, 05:42 PM
65panel5.3's Avatar
Ive always had good luck with b&m shiftkits, easy to put in and seem to shift like an sob. the one transgo i put in ive had nothing but problems, soggy shifting and flaring into 3rd gear. ive run the b&m for over 30000 miles now and love it.
Old 03-12-2011, 06:27 PM
SoCalCal's Avatar
I am getting a tune in a month or so, I heard you get shift firmness from it. I have a B&m transpak that I got for free!! I jus dont feel like paying someone to install it. The electronic shift is real cheap, thats the only reason why I have taken it into consideration.
Old 03-12-2011, 10:13 PM
sjsingle1's Avatar
i had a BM shift kit in my 700r.......it was pure crap......never again will i use a BM kit
Old 03-12-2011, 11:03 PM
SoCalCal's Avatar
Alright fellas, I got it, B&M sucs!!! So now can I get some feedback on electronic shift improvers vs actual kits that install to the tranny? I have heard transgo is a better kit to have, but I cant complain on the free B&M transpak.
Old 03-13-2011, 03:59 PM
Smile
id sell it and get a trans go.
Old 03-14-2011, 05:57 PM
65panel5.3's Avatar
as for 700r4's its usually not the shiftkit that makes them crap, they are prone to flaring and other problems inherantly so i wouldnt say that means the b&m is useless, for the 4l60e use the b&m. i would pay the money and have someone put it in. electronic is going to give you a little bit of performance but nothing like the shiftkit will. if you have the kit for free already then it shouldnt cost you much to get it put in. guaranteed a couple hundred dollars at most to get it installed. not all that tough to do.
Old 03-14-2011, 09:47 PM
SoCalCal's Avatar
Thanks 65. Your the first to answer the main question at hand. Ive heard good and bad things about the b&m, but I also have heard bad things about the transgo as well. Ive got the 4l60e so the b&m should be fine. The shop around here told me $200, im looking to around to get it cheaper. But again, thanks for the input.
Old 03-16-2011, 09:17 PM
65panel5.3's Avatar
happy to throw in my opinion and help anytime.
Old 03-16-2011, 11:42 PM
Jays_SSZ28's Avatar
Now look at the parts in the kit. You're paying $200 for them to install a few spacers, drill a few holes, and change a spring or two.
People who know this transmission even a little bit can make this kit out of nuts and drill bits.
The B&M might not cause a 2-3 flare because it does nothing to the 3rd gear circuit. People who know what they're doing can install the TransGo kit and not get a flare. Plus the TransGo kit does more than just make the shifts firm.
Old 03-17-2011, 11:01 AM
thunderstruck507's Avatar
b&m shiftkits... shift like an sob.
That they do, but not in a good way. Feels like the case is going to break every time they shift.
A good "shift kit" is about a lot more than upping line pressure and removing cushion springs.
Not a fan of jacking up the line pressure with the PCM either to answer your question about the "electric shift kit"
Old 03-17-2011, 07:53 PM
mine shifted like that. felt like my neck was going to break. i was happy to get that **** out of there and have a trans go installed.
Old 03-17-2011, 09:49 PM
65panel5.3's Avatar
we all have our opinions but if he has the kit already then i think for what hes looking for then the b&m will be fine, if he doesnt want the neck snapping shifts then just go with the rv/towing stage one and you will have a decent shift for a daily driver. most b&m kits have the 1 and 2 in the same kit so its up to socalcal to decide i guess.
Quick Reply: B&M electronic shift OR B&M transpak
