5/64in vs 1/16in piston rings.
Old 03-12-2011, 10:22 PM
henry172's Avatar
Default 5/64in vs 1/16in piston rings.
5/64in and 1/16in piston rings what rings are better for what applications and why?
Old 03-12-2011, 10:27 PM
WS Sick's Avatar
1/16s ring take way less power to push up and down the cylender.
1/16s = great compromise in withd and less parasitic drag.
5/64ths = durability and thats it...lol
Old 03-12-2011, 10:42 PM
Wicked94Z's Avatar
i'd run the thinnest rings you can afford for the application of the motor. Napier second is the way to go. No reason to run anything more than a 1/16 or 1.5mm compression ring when pro stock and comp eliminator are running less than a 1mm ring. What's the motor setup?
Old 03-12-2011, 10:57 PM
henry172's Avatar
Its just 355 with 11:8:1 compression, le1 heads with stainless valves, lt4 hot cam, 1.6 pro mags. I know I should install a little larger cam but it is just a CA daily driver car that will see the track two times a year max. Instead of a larger cam I am going to spend my cash on a stall. The guy who is balancing my rotating assembly was telling me the 5/64in ring pistons I had were not ideal, so I took his advice and ordered a set with 1/16in rings; so far it sounds like I made the correct choice. Wicked94Z do you run your car on the street, is it running a optispark?
Old 03-12-2011, 11:13 PM
1989GTA's Avatar
You made the right choice. I am running 1.5mm, 1.5mm, 3.0mm rings in my SBC setup.
Old 03-12-2011, 11:23 PM
Wicked94Z's Avatar
yea i street drive the car... hasn't passed smog in 6 years Yea I've got an opti on there still. Just as a distributor though, it's gutted. I run a crank trigger with the DFI for crank position. Car is down right now for the intake swap
The 1.5mm and 1/16" rings will last FOREVER in a street SBC, you'll be good. Watch out for bad fuel on that compression here in socal. I did my last motor in at 12.5:1 with a pretty big cam on this 91 octane down here.
Old 03-12-2011, 11:37 PM
henry172's Avatar
I would like to see that thing in person some day; I am not far from you in Glendora. I have relatives in rancho, upland and Fontana and I have never spotted your car on the street. Maybe one day I will see that monster going down the road. What fuel stations would you recommend for 91 octane? I have been using sams club 91 octane, but that was with a hot cam only lt1.
Old 03-13-2011, 01:16 AM
Wicked94Z's Avatar
Yea I grew up in glendora off lone hill, then claremont, and now I live in upland. I took my car off the street last month due to it being a smog year and not wanting to pay up. But when i get it running I'll give ya a ride around my house, the neighbors will love that I think my problem was Arco gas... stay away!
Old 03-13-2011, 08:56 PM
henry172's Avatar
Yep I have been warned to stay away from Arco gas a couple of times. Let me know when you have yours running I would like to check it out; hopefully mine is up and running soon, just waiting on those darn pistons.
Old 03-14-2011, 08:40 AM
quik95lt1's Avatar
the 1/16th top ring is just fine......I'm running a 1.2mm with no issues
Old 03-14-2011, 12:36 PM
henry172's Avatar
I O.K I think I will have a solid motor after everything is done; at least it should have quite a bit more than my hotcam only motor. I am going to give edge racing converters a call today to order my stall.
Quick Reply: 5/64in vs 1/16in piston rings.
