Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Eforce 2300 620rwhp/674rwtq
Old 03-13-2011, 09:40 PM
jweymar's Avatar
Default Eforce 2300 620rwhp/674rwtq
Will upload dyno graph when I can, and video.
I want to thank Charlie at Rpm for an amazing job. He went above and beyond the call of duty, custom fabing everything when he didnt need to. The car is just insane, I have never experienced such power. First and second completely usless. Third half works, but fourth gear is a rocket ship. I need more and better rubber asap!!!
Old 03-13-2011, 09:45 PM
98cobra's Avatar
So how do you order this kit? Its basically a camaro supercharger with the corvette ls2 lower manifold setup right? Actually just saw you have an ls3 so was it the camaro kit?
Old 03-13-2011, 09:48 PM
whisler151's Avatar
INSANE.
What are you gonna do about a rear?
Old 03-13-2011, 09:53 PM
jweymar's Avatar
Ya I have the LS3, but Charlie said he can do it for the ls2/6 as well. He has the exclusive access to the parts from Edlebrock. Call Charlie at RPM for info!
888-755-5391
or 661-299-6587
http://www.rpm-motors-inc.com/
Old 03-13-2011, 09:55 PM
jweymar's Avatar
Originally Posted by whisler151
INSANE.
I put Nut's billet 6060 Steel Diff in at the same time, that will hold it no problem!!
Old 03-13-2011, 09:56 PM
98cobra's Avatar
I Have an ls3 as well, what did it run you in parts without labor?
Old 03-13-2011, 09:57 PM
kzeliminator's Avatar
sickness!!!
Old 03-13-2011, 09:59 PM
whisler151's Avatar
Bad *** Sir.
itsslow98's Avatar
Congrats
Old 03-13-2011, 10:04 PM
jweymar's Avatar
Well it was a lot, but I got heads/cam/new diff/cats/brakes/ect/ect. I think with the complete catch can/oil check valve/bigger intercooler/custom intake its around 9k, but it depends on what you want. Charlie is a great guy, just ask him...
Old 03-13-2011, 10:05 PM
98cobra's Avatar
I will try him in the morning. A bare bones kit should be cheaper then the 2011 camaro advertised kit.
Old 03-13-2011, 10:19 PM
shadyLS6's Avatar
badass.. soo an upgrade to non-cathedral ported heads would be a precondition to running one of these on a LS6?
Old 03-13-2011, 10:23 PM
jweymar's Avatar
I dont believe so as they make one for a corvette ls2 with cathedral heads (I think). Charlie said he can do it.
Old 03-13-2011, 10:31 PM
jweymar's Avatar
A couple more shots
Attached Thumbnails Eforce 2300 620rwhp/674rwtq-car.jpg   Eforce 2300 620rwhp/674rwtq-car2.jpg   Eforce 2300 620rwhp/674rwtq-side.jpg
Old 03-13-2011, 10:35 PM
jweymar's Avatar
Old 03-13-2011, 10:37 PM
jweymar's Avatar
Old 03-13-2011, 10:55 PM
JJSimon904's Avatar
Looks good! There is a shop near me that wants to attempt the eforce on my car. How much boost are you running? I would imagine you could get a lot more out of it if you wanted to with the bottom end being forged
Old 03-13-2011, 11:07 PM
jweymar's Avatar
Running 10lbs, there is a lot left with timing and meth, and I am using a very large pulley. The Eforce is awesome about heat soak, Charlie said after 10 dyno runs the blower wasnt too hot to touch, and the power hadnt took a hit at all!! So I dont want to or need to run any more boost
Old 03-14-2011, 12:30 AM
JJSimon904's Avatar
Sounds like a pretty solid/safe setup! Good job!
Old 03-14-2011, 08:38 AM
JD03Cobra's Avatar
That is one bad caddy!
Quick Reply: Eforce 2300 620rwhp/674rwtq
