Western Members - Need a window expert
View Full Version : Need a window expert
b's90cam
03-13-2011, 11:26 PM
Looking for someone to replace my window regulators, not just the motors, and adjust the window and ttops to stop the leaks. Door panels will be off and the regulators have already been replaced so the rivets are gone. Anyone know a shop or someone good at doing this? I'm in the socal area.
Thanks,
Brandon
RPD_Vette84
03-14-2011, 12:07 AM
so your looking to change this whole part?
http://www.am-autoimages.com/partimage/WRG/AM-21115881/main.JPG
b's90cam
03-14-2011, 05:30 AM
Yeah, I was gonna get them both changed out nd install the autotrix kit. Figured since I'm changing the speakers out might as well. Passenger side definitely needs it and the driver side is new but couldn't get my hands in there enough to get the top 2 bolts in. Soooo... If any is especially talented at this pita job and can adjust the windows correctly I could use the help.
02Z28ZO6
03-14-2011, 05:03 PM
You cant really adjust the windows, they fit in one place. The problem is most likely that fact that they were installed with bolts. The bolts quickly come loose, then the regulator can move, allowing the window to come down a little bit. You need to install those with Rivets like they came from the factory. The rivets fill the holes completely wont wont let the regulator move. I learned the hard way, used bolts with lock tight and lock washers, they were loose and I had to re-do them in less than 3 months. Re installed them with rivets and they have been fine for almost 2 years now.
