PACKETFOCUS
03-13-2011, 11:35 PM
http://www.youtube.com/watch?v=_IV2Hwdvo_w
Went my new PB with the 98 camaro today on a wet 100 shot. I am still on the NA tune, so I just sprayed the 100 instead of 150 to be safe first time out. It was mid 70's today and the DA was 2500-2600 on my weather station.
Motor Pass:
1.76 60'
7.9 @ 87.25 - 1/8
12.44 @ 110.14 - 1/4
100 Shot
1.49 60'
7.51 @ 95.78 - 1/8
11.24 @ 119.5 - 1/4
I had the FJO Controller to spray 3000-6000 in 1,2, and 3rd. It was hitting the revlimiter about 1150' with the 4.10's. Seemed like the rev limit was set about 6400. Not for sure since I don't have much info on the motor tune. I'd like to bump it up a little later, but wanted to be safe and shot off the spray at 6000.
One big problem is the convertor in the car. It flashes about 3000 and I can stall it up to about 2600 before it wants to push the car. So with the low side rpm setting on 3000, it takes the car just a foot or so before the kit comes on. I'm thinking 4000 stall will help the car out a lot. Its a .581 TSP cam, LTs, ls6 intake, 9" with 4:10's, stock TB, Stock lid, AC Delete, full weight street car on pump gas.
The suspension is double adj AFCO's front and back with a wolfe anti-sway and madman LCA/swaybay. Seems to be dead hooking and pulled the tires a few inches on the 100 shot when I got up on the convertor hard staging.
I'm going to play around with the 100 shot and would like to get it in the 10's. But if I can find that in the tune-up, I will start pulling timing and move up to a 125 or 150. This is off the fuel rail with a stock pump so I don't want to push my luck on the bigger pills without a few upgrades.
Motor Pass:
1.76 60'
7.9 @ 87.25 - 1/8
100 Shot
1.49 60'
7.51 @ 95.78 - 1/8
11.24 @ 119.5 - 1/4
