can you use a rear O2 sensor as a front O2 sensor?
Old 03-14-2011, 05:53 AM
mikezohsix's Avatar
Default can you use a rear O2 sensor as a front O2 sensor?
If I swap the connectors, can I replace a bad front sensor with a good rear sensor?
Reading here someone said the rears have a bigger heater, will the PCM power it in the front?
Old 03-14-2011, 12:41 PM
bczee's Avatar
On the 99-02 F-Body, you can swap them around. I used rear ones on my swap... cause they were longer and made it to my collectors where my O2 is.
IMO, as long as they are of the same type.. and can be wired up.. you should be able to..
Quick Reply: can you use a rear O2 sensor as a front O2 sensor?
