mean98camz28
03-14-2011, 10:31 AM
miles:544
trans: 6 speed with hurst shifter
Suspension: QA1 coil-over adj. front and rear QA1 coil-over
exhaust: LT headers (slp), y Pipe (slp), and slp 345hp dual-dual exhaust performance
Throttle body: bbk 80mm
Richmond ring and pinoin 4.10 ratio
GM Performance cyclinder heads(part#25534321)(.035" machined off deck, 63cc chamber size, 10.8:1 ratio, cnc porting &hich Lift valve spring)
GM performance Camshaft(part#12480033) : LS1 "Hot Cam" specs are
intake exhaust
lobe lift 0.308 0.308
gross lift 0.525 0.525
lobe ctline 109deg. 115deg.
dura.@.006 271 280
dura.@.050 218 227
rocker ratio 1.7 1.7
valve adj. 0lash 0lash
lobe seperation 112
springs: part number 12565117
outside diamter 1.24"
installed height 1.801"
seat load: 90lbs
solid height: 1.217"
hyper-tech eeprom and thermostat
front shock tower stiffener bar
drive shaft safty loop
slp mass air flow sensor
build number # 2954
This car is the cleanest and newest car you will find for the 35th anniversary special edition with has the lowest miles you will find of only 544. this is being sold because of a very close family member. That has past away and this is one of his 10 cars in collection. he was a collector. if you are wanting more infomation on the car please call me 6087183880.
P.S. SERIOUS INQURIES ONLY.
intake exhaust
dura.@.006 271 280
dura.@.050 218 227
lobe seperation 112
seat load: 90lbs
build number # 2954
