Quick question about a thingy...
Old 03-14-2011, 06:17 PM
MasterTomos's Avatar
Default Quick question about a thingy...
I found a broken clip-in electrical connector on my motor today, driver's side of the motor, between the spark plugs, between the #1 and #3 cylinder. Looked through SH box, but couldn't seem to find exactly what it was. I can find and post up a picture if I need to, but I just wanted to know what it is, and how do I go about replacing it?
Thanks.
Old 03-14-2011, 06:26 PM
gregrob's Avatar
Coolant temp gauge sending unit
Old 03-14-2011, 06:27 PM
AChotrod's Avatar
yep^^^
Old 03-14-2011, 06:30 PM
jester1614's Avatar
that sounds like the coolant temperature sensor to me
Old 03-14-2011, 06:56 PM
Cool, thanks guys. It's plugged right into the cylinder head. I looked at it a little more and it looks like it broke right on the sensor side in the motor (the plastic part) and not on the wire/clip itself. Meaning I'll just have to replace the sensor.
Is that censor just something I can grab at the dealership or will I have to order it online? Is it just threaded in there, or what is the removal procedure? ( sorry it's getting dark in the garage now and my drop like just took a **** )
Thanks for the quick responces.
Old 03-14-2011, 07:00 PM
LT1559's Avatar
autozone.... $12 i think
Old 03-14-2011, 07:01 PM
LT1559's Avatar
make sure you get the right one, i took mine in a few weeks ago and asked for the coolant temp sensor...it turned out to be the coolant temp switch, or vice versa i forgot
Old 03-14-2011, 07:07 PM
Yeah I'll most likely pull it out and take it with me when I go to get a new one.
I was hoping this would have been the culprit to my car's surge in rpm at idle...not so lucky I geuss
Old 03-14-2011, 07:39 PM
jester1614's Avatar
if i remember correctly all that sensor is for is the gauge, its the one in the water pump that tells the ecu the temp. So i dont think that is your issue
Old 03-14-2011, 08:09 PM
James Montigny's Avatar
The one in the WP is for the PCM
http://shbox.com/1/temp_sensor1.jpg
The one in the head is for the gauge
http://shbox.com/1/temp_sensor2.jpg
They're cheap and easy to replace.
Pick one up at the parts store.
Old 03-14-2011, 10:07 PM
Cool, thanks guys
Old 03-14-2011, 10:34 PM
TheTransporter69's Avatar
remember when you take it out coolant will come out. just a fyi
Old 03-14-2011, 10:47 PM
^Thanks for the heads up! How much coolant should I expect?
Old 03-14-2011, 10:56 PM
i can't remember off hand, I had to change mine though, because i broke it putting in my lts. I just pulled it out quick and got the new one in as fast as i could and i lost a little bit. If your looking to take it out and into the store though maybe you want to drain your coolant.
Old 03-15-2011, 12:25 AM
gregrob's Avatar
A lot.
gregrob's Avatar
Nope.
Old 03-15-2011, 12:58 AM
jester1614's Avatar
Originally Posted by gregrob
Nope.
how is it not a coolant temperature sensor (as it measures coolant temperature), I never posted that it was for the ecu, i even posted in a later post what that one does as opposed to the sensor in the water pump
Quick Reply: Quick question about a thingy...
