Manual vs PS
Manual vs PS
So, im about to grab a bunch of parts for my swap, including most of what id need for my accessories. What im wondering is: how do you guys place PS in the list of priorities? This is for my 65 mustang, so itll be like 2900 lbs, but it will be a DD.
Should i keep the manual setup its got or grab a PS pump/reservior too?
I say leave it off, in a car that light it's not bad at all to steer assuming you have a manual rack or at least looped the power rack's lines together.
I was going to install PS on my fox swap and I scrapped the idea for several reasons:
Less drag on the motor, less stuff in my way when I'm working on it, less weight on the front of the car, less fluid to worry about, and the LS1 looks cleaner with out it. My .02
Forgot to mention also, the GM pump is a lot higher PSI output than the Ford rack can handle, so it'll blow rack seals or at least steer real twitchy. You're probably already aware, but for me I decided I didn't see the benefits out weighing the trouble to make it work.
I took mine out of my 91 mustang. Im running 18x9 up front and really its not that bad. Even my wife can turn the wheel going really slow. Of course going back to a power steering car is very weird now lol
For a DD, I would pony up for PS. Fighting manual steering in a parking lot sucks. If you are going for performance oriented suspension with more aggressive caster and wide tires, manual steering will be more difficult to manuever. If you're going cookie cutters and little caster, manual will be more manageable.
I'd say keep the manual rack. What's the ratio on the rack you're using? 18:1 15:1? Either way the 15 might be a little twitchy. I have an 18:1 in the Cobra.
I'll shoot you a PM of a guy who sells and electric PS kit that might work if you choose to go that route instead. I'm thinking about doing it on the cobra. No worries about the drag on the motor..
Tails
Tails
I can't find the link right now but all you need to do is remove the power steering pump, replace the smooth alternator tensioner pulley with a grooved one (put a washer behind it so it doesn't rub the alternator housing) and put on a new belt. IIRC the belt needs to be 55.5 inches.
Good question, I'd think it'd work and make it steer easier. Just a guess, though.
Yes, looping the lines and keeping the fluid in the rack makes a de-powered rack easier to turn than a dry de-powered rack. Lot of talk about this on the 944 Porsche forums because of the notorious leaking power steering system it has.
I say keep the manual box. I have used one for 17 years without a hang up. The only problems I have ever run into was when I had a spool in the rearend. Get the factory steering wheel as it is larger in diameter and will make it easier to steer. As far as brackets, I bought a unit off of a 2008 corvette that can be used either way p/s or not. I got the idler pulley, tensioner and pulley and the alternator bracket for $200. Kwik has a similar bracket and will prolly be cheaper in the long run considering I had to space the tensioner and alternator bracket out away since the F body balancer sticks out further. And also consider with the Kwik you can retain your factory alternator as for me I have to buy the corvette alternator. I like the corvette alternator since it has the clutch pulley which eliminates the harmonics in the belt. It will virtually run smooth rather than flop around. Since the alternator is spaced away from the centerline further the less harmonics the better. And if you decide to run the p/s later this bracket I purchased will accept the corvette p/s pump.
[IMG][/IMG]
[IMG][/IMG]
