Junkyard engine came w/o MAF. What replacement should I get?
My 2010 L96 6.0 came w/o a MAF cuz was ruined in the wreck. So I need a replacement. What MAFs will work? Is there a best one to get? I will have the car tuned to include dyno if that matters (and will be porting the TB). Just want to make sure the connector works with my stock harness that is being reworked. Appreciate your thoughts and counsel.
Easiest solution to both problems.
http://www.rockauto.com/
Mot much to gain out of a MAF, and you could have your current TB ported, but probably not much to gain there with anything other than a really radical build.
