Stereo & Electronics - Subthump or Kee Audio stealthbox for Trans Am?
chon79
03-15-2011, 09:55 AM
I've read some threads about fitment issues with Subthump on the Firebirds. Anyone order one recently to chime in?
I will be running a JL Audio 10w3v3. Just looking to see what experience people have had recently with either box and my sub combo. Thanks!
wrmathis
03-15-2011, 02:55 PM
i just got my subthump box but havent installed it yet. was gonna test fit today but had to replace the starter since mine pretty much broke in two. if i check it tomorrow, ill let u know
bobbyd
03-15-2011, 05:36 PM
i think you should be fine with both.
i have an mtx stealthbox and fits great. I wonder if kee still makes the passenger ones.
peterlawl84
03-15-2011, 06:33 PM
for pontiacs, I would recommend kee audio. I posted up awhile ago the issues I had with my subthump box. I was trying to return it, but he was adamant that the issue was with my car and that it must have been an accident (even though it never has) and did not let me return it. He finally let me send it back to him to trim the front piece. The fitment is ok, but definitely could be better.
I spoke with Kee audio in the meantime and found out that their box is designed from a pontiac while subthump used a camaro for the initial mold. The camaro cutout is alittle bit deeper than that of firebirds, hence the reason why I had fitment issues.
sdxp787
03-18-2011, 09:25 AM
I think he still advertises the passenger side box on his website.
wrmathis
03-18-2011, 01:34 PM
i put the subthump in my 94 trans am the other day and it fit. needed a little encouragement to get in there but i think it was due to the carpet gettin bunched up in there. anyways i got it in and had the plastic piece installed too
J-Train
03-18-2011, 01:42 PM
What holds it in there, if anything?
KEE AUDIO
03-18-2011, 02:36 PM
Generally it just is pressure fit in there. Once you get it in it's a tight fit...wow that doesn't sound right...anyway, when you put the hatch plastic back over it they never move. I have slid the T/A around sideways a few times with that enclosure in there and it doesn't move.
As for my enclosure vs. Subthump. Both are great quality and do the job fine. Subthump is a different design and will accommodate a deeper sub then mine. Of course I also can modify mine to allow a larger sub as well which I have done a few times.
Both are quality and will make great bass in a compact space.
chon79
03-18-2011, 03:14 PM
^Hey Kee, would your stealthbox be a great match for a 10w3v3 sub?
wrmathis
03-18-2011, 07:53 PM
thats why i went with subthump. cuz it has a deeper design. and like Kee said. it doesnt move once u get it in there. and i had to persuade mine to get in there if u know what mean. just need to get the headunit i want in and i can install everything. cant wait to get rid of the stock speakers
J-Train
03-18-2011, 11:29 PM
So for a L7, I would probaly need a subthump then huh?
KEE AUDIO
03-19-2011, 12:35 AM
Yep. I do not have anything for an L7 currently....sorry! If there is anything else I can help you with just let me know!
As for a W3V3 JL subs my enclosure would be fine and work very well with that sub. It is similar to the CDT HD1000CF I use alot and have used the W3 a few times. Sounded great!
stealth355tpi
03-19-2011, 09:30 AM
Hey Ian its kyle, any word on the fiberglass box yet?
KEE AUDIO
03-19-2011, 09:49 AM
Hi Kyle,
I haven't done anything in fiberglass lately. I still have 2 shells though. You needed an L7 one correct?
stealth355tpi
03-19-2011, 09:55 AM
yea still need it, 10inch thanks
Cwillits505
03-20-2011, 11:10 PM
Kee! Im an Fbody Newb.. and a proud one at that, love my new (to me) TA. Anywayrs, the system the guy has in it when sold to me is stock monsoon and some nice kicker 12's, after alot of tuning I have it sounding descent enough, here is my issue as many others have discussed in the forum, tweeter placement, more importantly, leg block!! From all I can tell (like I said, newb) you are the trusted man with Fbody audio, and I love the look of your products, do you or anyone you know of have tweeter suggestions? A-pillar somewhere/6LE Pods? love the look of the pods but if $175 is not necessary... well... any help would be great guys! and correct me if Im wrong, tweeters are wired to the head unit, NOT the monsoon amp, so ive heard.... so I could replace with aftermarket no problem?
