Cadillac CTS-V - Wtf now im pissied!
plastus85
03-15-2011, 07:49 PM
i know you guys are thinking, geez another motor mount thread... but seriously what the fuck.
i broke a uuc mm about 3 weeks ago and Luke hooked me up with a new one quickly.
now after 2 WEEKS, heres the one he sent me.
And yes i install them properly, i dont think you can screw it up. i didnt even tighten it very hard this time. This is from the drivers side, the passanger side is holding up great
http://i257.photobucket.com/albums/hh218/konrad_29/2011-03-15191755.jpg
CGMLS3
03-15-2011, 08:06 PM
Fail! That sucks.
racebyu
03-15-2011, 08:19 PM
Time for a revision mod on the UUC bushing I guess, sorry to hear about your grief :bang:
The pass. Side is holding up because the motors deflection is into the mount(compressing). The drivers side is separating the mount (pulling away). Looks like they have a bonding issue with the mount poly and the hardware. You shouldn't have to deal with this at the price of those mounts.
What tranny mount do you have?
98cobra
03-15-2011, 08:51 PM
Creative Steel time
itsslow98
03-15-2011, 09:48 PM
stocker time.........all these aftermarket mounts seem to be just as bad in their own way.
raven154
03-15-2011, 10:16 PM
Someone needs to make another run of RC51 style mounts!!!
tommycompton
03-15-2011, 11:11 PM
I'd ask fo a refund and buy the creative steel black ones, never a failure i've heard of.
chitown21y
03-15-2011, 11:19 PM
CS black
DrSpeed
03-16-2011, 12:20 AM
I still can't believe UUC just injection molds that garbage with a simple hex head bolt and sells it as a "premium" motormount.
At least weld a fender washer to it so it has more bite, and interlock the upper/lower stud so that when it does fail, the motor doesn't just fall out.
shadyLS6
03-16-2011, 07:19 AM
i dont even wanna think about swapping MM multiple times... now thats Mod Hell:bang:
:yup:
I have never seen a pic/or a report of a OEM trans mount failing or even being damaged.. why change?? i have heard of people complaining of new vibs with aftermarket trans mounts tho...
Stepside
03-16-2011, 07:40 AM
Maybe Lindsay Cadillac needs to change their supplier to Creative Steel.
GulfM3
03-16-2011, 08:13 AM
THIS!!!! The RC51 mounts are the best design mount out there, and nobody has had one fail. If I cant find a set I'll be making my own.
My CS gray poly motor mounts are melting, anyone who uses them needs to heat wrap them and use the supplied heat shields. They melted when I had Kooks 1 7/8" headers, I haven't checked them since the turbo install, which uses the stock manifold. Yes I installed the motor mount heat shields.
JJSimon904
03-16-2011, 09:20 AM
If someone does a run of RC51-style mounts then I'll buy them, if not it will be 100% solid for me..lol
ferny
03-16-2011, 12:40 PM
torque sucks! lol..jk
Slithering_Joe
03-16-2011, 12:46 PM
UMI Performance Inc. in Philipsburg, PA is developing a set similar to the "RC51" style mounts.
UMI Performance
03-16-2011, 02:55 PM
Yes we are, I have a set completed... I will pass them on for pictures ASAP so I can post them.
tommycompton
03-16-2011, 03:19 PM
http://i36.photobucket.com/albums/e29/tommycompton/trannymount.jpg
FAIL!!!
GulfM3
03-16-2011, 03:31 PM
Very interested!!
FAIL!!!
I dont know what looks worse, the busted mount or your crazy double jointed finger :D
Thats the first failed trans mount I have ever seen, good job on driving your car to it's limits!
JJSimon904
03-16-2011, 03:52 PM
Very interested!!
Me too!
FRiCK
03-16-2011, 04:08 PM
Me too!
Me 3!!
tommycompton
03-16-2011, 04:29 PM
I think it failed because my OEM motor mounts were so shot. I would never go back to OEM (junk).
shadyLS6
03-16-2011, 05:13 PM
nice more options.:D:D.. anything going to be done about the transmission of vibrations through the solid mounts???
solid mount are great and all but vibs are the whole reason my RC51 MM are sitting on the shelf
haha i stand corrected.. only problem with the aftermarket mounts are that they dont include a positive lock like the OEM designs..its all poly and when that fails you got nothing.. with tha being said im running MM that dont have a positive lock so ill just STFU now hahah
tommycompton
03-16-2011, 06:17 PM
The tranny doesn't really have anywhere to go except maybe up. I don't think the engine would go anywhere either, unless all mounts failed at once.
With the oem failed tranny mount when I went over speed bumps I could feel my shifter rise in my hand, then the the tranny would clunk back down.
I have UUC now, but plan on switching it out to a Creative steel grey mount.
heavymetals
03-16-2011, 07:20 PM
I believe they look similar to the PADFT for the VETTE's
LS1iFiEd
03-16-2011, 07:36 PM
Sorry if this sounds dumb, But what does it feel like when the mount comes apart such as yours? Is the motor bouncing around and clunking? Just want the heads up to pay attention to mine as I bought and installed mine a few months ago.
blk04V
03-16-2011, 07:50 PM
this is what I have on the drivers side - passenger side is UUC and so far so great...
raven154
03-16-2011, 08:15 PM
Honestly they aren't that bad. They are not a solid mount. The RC51 mounts have a poly bushing that has star pattern to it almost. It makes it so they aren't as stiff as a solid bushing.
Also, the CS trans mount supposedly has a fail safe similar to the OEM mount in case of failure. Personally, I had the UUC trans mount and I threw it in the trash and learned a long time ago UUC is a joke. I run the RC51 mounts with the stock trans mount and even with a loppy cam it's really not bad! I know they are much better than failed OEM mounts lol
plastus85
03-16-2011, 08:52 PM
this time i felt and heard a clunking when i decided to look under the car. im getting pretty good at changing motor mounts (and removing longtubes) lol. also spoke with UUC today, and they told me the design was changed and i will be recieving the new one.
bamacaddy
03-16-2011, 09:17 PM
Post up some pics of the new ones.....I'm just curious to see what's changed on the setup
liqidvenom
03-16-2011, 09:20 PM
im curious to see what the UMI ones look like.
Not shocked to see the resident MM guru Joe pop in here.
DrSpeed
03-17-2011, 11:01 AM
If someone can get me some dimensions on the RC51 mounts, P/N's for the bushing used, or if someone has some on the shelf, I have a buddy that can fab some up, and get a price to see if he's willing to make another run of them.
I can coordinate this effort as well.
liqidvenom
03-17-2011, 11:52 AM
I dont understand why the idea for those mounts werent carried on... people just loving the UUC stuff.
plastus85
03-17-2011, 01:55 PM
They look identical
Trust me. Replace the tranny mount while your at it. Takes twenty minutes. If the tranny mount is worn/damaged/separated, it will allow the motor to deflect even more. You have give somewhere allowing your motor to deflect and separate your drivers side mount.
Bad workmanship- possibility YES!
But do you want to replace MM and tranny again wh you find out it's not a workmanship issue?
It's up to you. The Internet is full of tons of good info, and twice as much bad. You have to think logically on your own, because it's your car and your money. Just look at the big picture. Two failed UUC!?
Tranny and vibes - I have CS mm and tranny, no excess vibes here. Anyone else?
ColeGraham
03-18-2011, 02:34 AM
this whole mount issue is weird...some have failures and some dont. be it the stockers, UUC, or CS. some have melted and some are doing fine.
my stockers were shot after 33k on the clock. so, rather then getting stockers replace under warranty (since a lot of had issue doing that with a modded car), i replaced them with UUC at the recommendation of my shop. i now have almost 10k miles on them, with no issues. i am running Kooks LTs with Jet Hot 1700 Coating and the MM have header wrap and heat sheilds with them.
OP, sorry to here about the bad luck. hope you get her back up soon with no other problems
CORNER CARVER
03-18-2011, 08:22 AM
I made my own. The factory mount was trashed. Too weak of a design in my opinion.
At the same time I filled the factory trans mount. I will say that the filled oem trans mount transfers more internal transmission gear noise to the cabin. It could totally be contributed to the fact that is 94 hardness rubber.
bamacaddy
03-18-2011, 08:59 AM
We all know your mod list by now COLE.....Oh wait sorry wrong thread:D
Slithering_Joe
03-20-2011, 11:54 AM
Structurally, the RC51, UMI, and the PFADT designs are pretty much the same. The PFADT are really nice looking.
"RC51"
http://i189.photobucket.com/albums/z130/Slithering_Joe/Misc/CIMG7436.jpg
PFADT, $250
http://www.pfadtracing.com/catalog/images/C56%20Engine%20Mounts.jpg
Looking at the UUC abortion of a design, it's just a matter of time until they fail. I'd hate to be the guy hitting the throttle hard after apexing a turn then to have the motor rip the mount. Or, Id hate to be the guy driving behind him/her. Just say'n.
raven154
03-20-2011, 06:33 PM
With a stud that long on the bottom of the pfadt mount, I bet you could make a spacer and make them work. Just sayin.
CORNER CARVER
03-21-2011, 12:10 PM
Those would work.
