Which of these cams would fit my needs.
Going into a 1999 fbody...motor is a tsp 408 with ls3/l92 heads 64cc, -4cc pistons and fast 102 manifold..backed by. A th400 trans with a 4400stall.
9in wit 3:90 ..and car would weigh about 3700 wit me in it..nd the car would see 85% of the track and about 10% street car..mainly for shows... And 5% parked lol
Here are the cams
1st:
Product Information
Intake Duration: 239 Degrees at .050" Tappet Lift.
Intake Lift: .624" with 1.7 rockers.
Exhaust Duration 271 Degrees at .050" Tappet Lift
Exhaust Lift .624" with 1.7 rockers.
108 Degree LSA
Designed Fordum6.2 to 7.4 Liter Engines With Stock Or Stock Type Intake Manifolds and Rectangular Port Heads.
Extensive Computer Tuning Required.
Suited for applications needing concentrated high rpm power.
Dual valvesprings recommended.
3500 to 7000 RPM Operating Range.
And 2nd
Product Information
Intake Duration: 236 Degrees at .050" Tappet Lift.
Intake Lift: .612" with 1.7 rockers.
Exhaust Duration 262 Degrees at .050" Tappet Lift
Exhaust Lift .646" with 1.7 rockers.
114 Degree LSA
Designed Fordum6.0 to 7.4 Liter Engines With Stock Or Stock Type Intake Manifolds and Rectangular Port Heads.
Aggressive High RPM Power Band.
Exclusive lobe design works well with 1.8 rockers.
Works well with nitrous oxide.
Dual valve springs recommended.
Here are the cams
1st:
Product Information
108 Degree LSA
And 2nd
Product Information
114 Degree LSA
I've seen those cam specs before. EPS shelf grinds (no secrets). Personally, I like the 2nd one (with maybe a little more LSA) listed on the All Motor Page for Rectangular Port Heads. But I was thinking about a few more cubes than what you have. I'm sure the guy that specs those cams would spec you a custom one if you're interested.
LS 230/246
Product Information
Intake Duration: 230 Degrees at .050" Tappet Lift.
Intake Lift: .600" with 1.7 rockers.
Exhaust Duration 246 Degrees at .050" Tappet Lift
Exhaust Lift .607" with 1.7 rockers.
113 Degree LSA
Designed For 6.0 to 7.4 Liter Engines With Stock Or Stock Type Intake Manifolds and Rectangular Port Heads.
Computer Tuning Required. Broad Power Band.
Aggressive idle and strong mid-range power.
1500 to 6800 RPM Operating Range.
LS 230/246
Product Information
113 Degree LSA
To the OP if you have spent this much money so far why not get something ground to suit your needs? Call up Geoff or get in touch with Pat G and get them to grind you something to meet your expectations.
I
Got those off geoff page or should i say engpwrsys.com
Im runnin a pretty similar one to the 230/246.. Im
Running a 230/244/114 lsa but this is in my silverado..but now this motor going into my 99fbody
FWIW: I made very nice power - 520/475 - with a 234-240 112 +0 on XE-R lobes in my 403. I've now run 3 cams in the 403 and one in the 427. The sweet spot for the intake on these heads seems to be in the 230 to 234 duration range. I've havent run any cam with over 242 on the exhaust. Don't push CR past about 11.4:1 or you won't be able to run enough timing to make power. The heads have like 28-30 degrees to make power.
Just my $.02
Just my $.02
Well, those are Geoff's off the shelf rect port grinds. Speak what you want, but we know Geoff don't spec junk.
Just because people have a different opinion on what to run does not take anything away from what those two have done.....
But I will tell you this, open your eyes and broaden your horizon because there are thousands of guys running other cams that work and have worked well... There is a whole entire world outside of the box, Now if your allegance is with those two, thats fine....
But don't put words in my mouth that I never said and I did not see WKMCD say either, now your just being messy ......
Think outside the box, don't be a sheep bro.... I see marketing has power.....
Bozz
Nobody ever said they do, you made that assumption......
But I will tell you this, open your eyes and broaden your arisen because there are thousands of guys running other cams that work and have worked well... There is a whole entire world outside of the box, Now if your allegance is with those two, thats fine....
Bozz
Bozz
So none of us knows if any Geoff's cams will or will not make power so....you need to think "out of the box".
I have a 416 build going on right now that Geoff has spec'd the cam for. I will post up the results when it is done and we can talk about it more in another thread.
By the way I have broadened my "horizon" because I don't know what an "arisen" is.
Don't get it twisted. The OP stated he wanted something for 85% track which would be something that would make good power. You and WKMCD posted your opinion that you didn't like what you saw which in turn means you don't think it would make good power. I will agree that I have not seen a build with Geoff's cams but none of us has seen any. WKMCD has a combo from Shawn at Virginia Speed that makes good power so he believes in what he has seen from VS and I believe that Shawn spec's very good combos.
Bottomline:
Your trying to create a controversy and there is no need for that, like I said you were being messy.......
I never said I did not like the Geoff lobes or that they were junk, you said that, I said I do not care for the the cam specs, so once again, quit being messy and trying to create some flaming controversy.......
You "azzumed", no need to spell check that...
Bozz
You can always follow the paper trail and the dollar because the dollar leads the brain and the mouth for many.... Son, I can see out of the box and far past the box your in sitting on a shelf in a warehouse... If internet dynowars are what you're into, I will bow out and give it to you, you're the champ, because thats not what I am into.....
Bottomline:
Bozz
Bottomline:
Bozz
You're just trying to bow out gracefully now. How about you throw up a cam spec since you don't care about the stated grinds? With your grammar I suspect you will spec out 290/211 480/525 118
To the OP good choice in getting something custom spec'd.
You can always follow the paper trail and the dollar because the dollar leads the brain and the mouth for many.... Son, I can see out of the box and far past the box your in sitting on a shelf in a warehouse... If internet dynowars are what your into, I will bow out and give it to you, your the champ, because thats not what I am into.....
Bottomline:
Bozz
Bottomline:
Bozz
but that's just my opinion from the specs posted.as we all know(or should know)there's a lot more to a cam then specs at .050.
i don't like the specs of the cams either,for a STREET car.both descriptions clearly state these are high rpm cams.i think both would work well for the intended purpose,which would basically be a drag only car,with steep gears,high stall converter,etc.definately something i wouldn't choose if it was my car.
i have a pretty high stall 4400.. 3;90 gears, etc
Call Geoff or somebody you would trust that would point you in the right direction on a cam that would suit your needs. They might put you on some different lobes that are more aggressive since it will mostly be a track car. That's what Geoff did for me, but most, maybe all the people you can think of that is reputable to spec a cam will put you more on the aggressive lobe profiles.
