help with a 95 z28?
help with a 95 z28?
Hey guys, i've got a 1995 z28 with a lt1 and a six speed. it's a pretty fast car as you might already know but i'm not satisfied with it quite yet. now keep in mind im only 16 so i'm on a pretty tight budget. so these are my questions, and thanks for the help in advance.
1. i want to put a bigger cam in the car, i have a mechanic that helps me with this stuff but i wanted to see ya'lls opinion. i think i'm going with the cc306 (.510/.540 i think) and i figured i would probably need to get my heads p/p and maybe put a aftermarket chip in it? anything else?
2. what good is a cam without an exhaust? i decided i want to put aftermarket exhaust. i've heard of people bolting their mufflers straight to their headers, is that possible? if not, i was thinking headers straight back to mufflers in the back, any recommendations? i want a clear sound so i can hear that cam very easily.
3. well i decided that i couldnt have a muscle car without rims. i want the weld prostar 15x10's on the back and the 15x4s on the front, the only problem is i looked at my rear wheel wells and i'm not sure that i can fit those on there... but then again idk when it comes to backspacing and offset and all, i guess what i'm asking is can i put that rim on there without it rubbing the inside or sticking outside the wheel well?
4. last thing, when i go very slow (in first gear) and i push my clutch in it runs a high rpm (2000 or so) and stays there for a minute or until i let off the clutch. i made sure it wasnt my foot, any ideas??
Any help greatly appreciated!
well the 95 doesnt have a chip, you can get a mail order tune or take it and get a dyno tune. You can look here to find a cam thats works for you
https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
Just a start for ya
Just a start for ya
Read here first https://ls1tech.com/forums/lt1-lt4-m...ewbie-faq.html
Start slow and do all the bolt-ons. Don't go throw a cam in with everything else stock
hey, i read up on that guide, thats actually where i found that cc306 cam. so are you saying that since it doesnt have a chip in it, i really would only need to get the heads p/p maybe?
thanks for the quick responses guys. i guess what i realy want is my goal would be 400hp. now i considered makin it a 383 and a couple other things but what i would really like to do is put a cam in it, i see you said do the bolt ons first but if i was to put a bigger cam in it, what all would i need to replace/add? keep in mind im on a budget.
Oh, and a 383 isn't going to be anywhere near any kind of low budget, if you want it done correctly and to make good power while still streetable.
It depends on the size of the cam. Start with CAI, headers and exhaust. For 400hp look at LE or Ai to get a head/cam package. Since you're 6-speed look for a good clutch and hope you don't hook good so you're rear end doesn't break. For a good daily driver go with bolt-ons and a set of 4.10s and you'll think its a different car
alright i think i'm headed in the right direction now. so first bolt ons, like on the intake, then exhaust, right? and i saw you said that head cam package, i've heard alot about that. any ideas on exhaust?
Yeah for bolt-on get a good cold air intake. Then get a set of longtubes and figure out what kind of exhaust you want the easiest would be to get a off-road y-pipe and a good flowing catback like hooker or loudmouth depending on how loud you can deal with.
