Complete Bullsh*t
Old 03-17-2011, 11:06 AM
1998MysticZ28's Avatar
Default Complete Bullsh*t
Pardon me for my rant but this is the second time I have taken my car to the track and the same thing happened. A the track officials suck so bad I could only get two runs in that night. Second thing has to do with my transmission. I have a FTI 3600 stall speed in a built 4L60E. Im still on street tires, so I tried baby launching the car, and obviously spin out the hole. I back off the pedal to try to catch up and the car will shift into second or third, and it just bogged the whole way down the 1/4.
Same thing happened on the second run. So when I left, I try the same thing on the street and it works perfectly. Im really at a lost of words here, anyone have any Idea?
Old 03-17-2011, 11:10 AM
slo98bird's Avatar
when ever i run street tires at the track i hold the gear selector in 1, after i launch and catch traction i will slide it up to D and go from there. it works for me, couldnt hurt to try it
Old 03-17-2011, 11:21 AM
Last time I tried that, I shifted at like 5000 rpm it went to Redline bounced off it, then shifted. Did the same from 2nd to 3rd
Old 03-17-2011, 12:39 PM
I have tried searching but have come up with nothing
Old 03-17-2011, 01:06 PM
ArkBird96's Avatar
when shifting manually, you have to realize that there will be a delay between when a shift is commanded and when it actually happens, hence hitting the redline.
Old 03-17-2011, 03:37 PM
IDRIVEAG8GT's Avatar
You need a trans tune.
Old 03-17-2011, 04:57 PM
Jays_SSZ28's Avatar
And you have no idea why it spins, hooks, shifts, spins, hooks, shifts?
Old 03-17-2011, 05:00 PM
thunderstruck507's Avatar
I guess it's also possible it's going into limp/abuse mode.
Get some drag radials.
Old 03-17-2011, 05:12 PM
lt1-xjs's Avatar
You have no reason to complain if you are running street tires. Get some real rubber and let it rip.
Old 03-17-2011, 05:22 PM
I'm not talking about the fact that it spins. I know that it's gonna spin. If you read the post I said it spun and when I tried to throttle it it went into a higher gear and bogged.
And when I shifted it manually, I realize you have to give it time to shift but 2000 RPms no.
Old 03-17-2011, 05:30 PM
jgarza54's Avatar
When you are on street tires, street and track are 2 different things.. On the street with street tires, you can keep spinning and it will shift to second and third and still have the power to keep the rpms up till it catches traction.. At the track where there's better traction, you'll have the power to spin 1st, 2nd, and 3rd, but as soon as it catches traction (will catch traction faster than on the street) depending on what rpm and what gear you are at, one of two things will happen. 1) You will bog, as what happen to you already, or it will be at a too low of an rpm and down shift causing it to spin again kicking it to the next gear again, where you will catch traction and bog again...
When I race on street tires I will manually shift my car. When I shift from 1st to 2nd my trans will shift right when I throw it into 2nd without a delay. Now from 2nd to 3rd third there is a delay of maybe 3 to 4 hundred rpms.. Im with IDRIVEAG8GT you need a trans tune and also get you some DRs. I hope this helps you understand what going on with your car at the track..
Old 03-17-2011, 07:56 PM
racerrit's Avatar
Definately need a trans tune and some drag radials!
Old 03-17-2011, 09:53 PM
SILVER 2288 SS's Avatar
Location: boaring place where theres more cows than people
mines been dong that as well man jst need to have the trans tune tweaked. STAY AWAY FROM RPE lol
Old 03-18-2011, 01:40 AM
RPE doesnt exist anymore that god
Old 03-18-2011, 01:53 AM
I have a temporary solution. Bag of Lays Jalapeno Potato Chips, and Mt. Dew. That will prepare you for the long run to give Lou at Mad Dog a call and have him build you a 4L60 with guts out of the truck 4L70 and a super servo/ with a Corvette 1-2. Then get the HP Tuners VCM Suite, become a member of the HPT forum and then we will make you your own personalized trans driving and racing tune.
Old 03-18-2011, 11:25 AM
Jays_SSZ28's Avatar
You need tires.
The transmission shifts mainly off mph.
When you spin your tires mph goes up and it upshifts, but the car is going too slow so it bogs. It might or might not downshift back down but if it did it would start the whole process all over again. If it didn't it would bog.
With traction your entire car and drivetrain will reach shift mph and the next gear would catch when the rpm was high enough to keep pulling.
Old 03-18-2011, 01:00 PM
Dan
Dan's Avatar
I never understand why a car with 410hp runs street tires. You are wasting your time, get some tires & you will be way happier. Put the trans in D & let it shift itself, not sure why people manually shift an auto either.
Old 03-18-2011, 01:03 PM
c6matt's Avatar
Originally Posted by IDRIVEAG8GT
I have a temporary solution. give Lou at Mad Dog a call and have him build you a 4L60
any sad dog transmission is "temporary" ..
Old 03-18-2011, 01:50 PM
01ssreda4's Avatar
Better tires, or dont let out of the gas. I've done both
Old 03-18-2011, 04:24 PM
CRAZYCUTER4.8's Avatar
LOL, Lou @ MAD DOG? Isn't that the brother of the scamming greek guy who owns Monster transmission, That is his 3rd or 4th transmission company he has started. If you are in the industry at all you know the stories...not pretty. There are plenty Sponsors on here that do work above the board. I am not a basher, please dont take it as such, but I have seen the guts of some builds with used stock steels....ect..
