Correct Sealant or Loc-Tite for Rocker Studs
Did a little searching and could not find a definite answer. What sealant should be used on the threads of the rocker studs on stock aluminium castings?
I have seen, no sealant, 30w oil, ARP sealant with PTFE, Blue/Red/Green Loc-Tite, and Permatex No.2.
Thanks
Thanks
gregrob I noticed that you recommended the Green Loc-Tite in another thread. Did you find a problem with the product and this application? I didn't think to check if they were stock castings the OP had.
I am cutting down my guide plates tonight and want to use the correct product on the rocker studs this time around.
Keep em coming. Thanks!
Thats what I thought when I was porting them. Never saw any holes in the intake runners. But I read through this thread and found its apparently a rare occurrence.
As for sealing a blind hole, I just feel its good practice. Not completely necessary if you're positive the porting didn't uncover the holes, but then again it does keep oilout of the threads regardless...
I put a set of roller rockers in my car several years ago. Since I was already in there, I thought I'd throw in a set of ARP studs. I didn't use any Loc-Tite or sealant. Why? The OE studs didn't have any, so I assume that GM felt it wasn't necessary. Torqued them to 50 ft/lbs and called it a day...
Sounds good. Ill be picking up some high temp sealant and heading to my shop in about 20 mins.
Another thread involving rocker studs... https://ls1tech.com/forums/lt1-lt4-m...ker-studs.html
gregrob your post number 2 in the above thread. I was eyeballing the green stuff a few weeks ago but settled with blue. I will be switching to Loctite 37398 thread sealant. Ive used it before at work. Well see what happens.
