Need Your Help: NO START PROBLEM
all started the other day my car was cranking but not starting. i have been having some fueling problem. well i decide to change a relay thinking it was a external fuel pump relay. end up being a relay to my scavenger pump. anyways i take the relay out and switch it for one i bought. i jumped in the car and nothing happened when i put the key in the start position. doors just locked that was it. nothing comes on. no fuel pump. no scavenger pump. no radio. no lights on the dash. nothing. i put the old relay back in and still nothing. what could it be?
i was thinking the ignition switch and litterally just got done changing it. and still same prob
1 Post
Sounds like an electrical wireing or connection issue, did anything happen that might have caused this? I guess the next thing you could do is start checking voltage readings, I woulda figured it was the ignition as well..
