Stock tune big injectors
Not a good idea. You will wash the walls with gas and run PIG PIG rich. Get it tuned first or park it until you do. Made that mistake when I first built my motor over 11 years ago and diluted the hell outta the oil. Thought I had more gas then oil in there when I drained the oil pan. When you dilute the oil by washing the cyl walls with gas you run the risk of damaging the bearings and also the piston rings.
