4l60e help!!!!
Old 03-17-2011, 05:13 PM
TURBO_HOE's Avatar
Default 4l60e help!!!!
So after my car sitting for about 3 days. I jumped in to take a drive and about 4 blocks down the road the tranny just lost all gears. Now when I turn it off,and start it again it'll run and drive for like 2 block then no gears again! I've had no problems til now the trans is a proforma built stage2,and fuddle 3500 stall someone said the front pump is out any ideas
Old 03-17-2011, 07:39 PM
joecar's Avatar
Did you check the fluid level...?
Old 03-17-2011, 07:49 PM
racerrit's Avatar
If ur fluid level is good u need to check pressure to see whats up.
Old 03-17-2011, 09:55 PM
SILVER 2288 SS's Avatar
Location: boaring place where theres more cows than people
my car did the same thing after the cam install i did. i jst replaced the shift solenoids and it works fine
Old 03-17-2011, 10:56 PM
TURBO_HOE's Avatar
fluid level is good, how do you check pressure?
solenoids will be next.
Old 03-18-2011, 03:36 PM
TURBO_HOE's Avatar
Ok changing the filter,fluid,and shift selenoids tonight any other suggestions? How hard is it to change the front pump
Old 03-18-2011, 05:14 PM
joecar's Avatar
Trans is removed from vehicle, valve body is removed from trans, pump comes out from front after bell housing.
Old 03-19-2011, 11:59 AM
TURBO_HOE's Avatar
If it's really that easy I'm doing that to.
So if I just change the fluid/filter should I also pull the valve body and clean it to?
Old 03-20-2011, 11:06 PM
LVTubasoR's Avatar
hmmmmm does this ussualy happends to does performabuilt Trans? i was about to order one, but decideit to read here first not happy...
Old 03-21-2011, 12:30 PM
TURBO_HOE's Avatar
Ok well I change fluid,filter,and solenoids but now here is the problem. The car drives but feels like only 1,2 and overdrive is working and if I manual shift it the trans make a thump like its dropping in to that gear.
Any thoughts about this?
