Coolant Leak
Old 03-18-2011, 03:03 PM
jetaws6's Avatar
Default Coolant Leak
I have a coolant leak someone in the back of the motor. Its not the block off crossover pipe plugs and it looks like its coming from the passenger side. I had it jacked up and running but I didn't see anything leaking. but there was a drip from somewhere.
Where else can I check?
Old 03-18-2011, 08:01 PM
SOMbitch's Avatar
My guess is the heater hose or HH fitting. If you can pressurize the cooling system you will prolly figure it out quick.....
Old 03-18-2011, 08:02 PM
13lu91rS's Avatar
get a pressure tester.
Old 03-19-2011, 01:47 PM
jetaws6's Avatar
what will a pressure tester tell me?
Old 03-19-2011, 09:24 PM
01BlackCamaroSS's Avatar
It will tell you if your cooling system is holding the correct pressure as well as help pinpoint the leak that you are looking for
Old 03-19-2011, 09:36 PM
LaBLKv6Z's Avatar
Yeah it works great, just put 16 psi and look for a nice stream lol. Mine ended up being the plastic restrictor valve on the bigger heater hose.
Old 03-20-2011, 12:04 PM
jetaws6's Avatar
alright 16 psi sounds good
Old 03-20-2011, 01:02 PM
O2Form's Avatar
Plastic restrictor valve....I'd love to hear all about this restrictor valve.
Old 03-20-2011, 09:44 PM
LaBLKv6Z's Avatar
Part number is 74796 if you need one..
http://www.autozone.com/autozone/par...mString=search
Old 03-21-2011, 06:40 AM
O2Form's Avatar
I stand corrected! So where are they putting this restrictor valve...I've never seen it on my 99 or 02 fbody?
Old 03-21-2011, 12:44 PM
LaBLKv6Z's Avatar
Its on the bigger heater hose (3/4") between the pump and core.
Old 03-21-2011, 09:46 PM
joecar's Avatar
I don't see it.
Old 03-22-2011, 08:28 AM
jetaws6's Avatar
Well I tool a pressure tester to it last night and it turns out there are two leaks. One coming from a hose on the water pump and the other I haven't found yet but its not the heater core.
Old 03-22-2011, 02:42 PM
LS6427's Avatar
I don;t see a restrictor valve on mine either........
Old 03-22-2011, 02:49 PM
LaBLKv6Z's Avatar
Originally Posted by joecar
I don't see it.
Getting alittle off track of the thread. Are you the original owner of the car? I've read that most guys just do away with it all together once it starts to leak. I just pointed out that mine leaked and it was a place to check to possibly help out the OP. Hell, OP might not even have one anymore either lol. (......)
Old 03-22-2011, 03:47 PM
joecar's Avatar
Closer to which end...?
(yah, I'm the original owner)
It's related to this thread, the rest of us can go an check our restrictors.
Old 03-22-2011, 10:11 PM
LaBLKv6Z's Avatar
When it was stock, it was mounted with pressed fittings, now I have it held in with worm clamps. Mine is bypassed at the moment because I don't feel like draining coolant everywhere again.
