Replacing front crank seal
Old 03-18-2011, 07:13 PM
trey1010's Avatar
Default Replacing front crank seal
Hey everyone, having a hard time here. Just did a cam swap and forgot to replace the front crank seal. But I already have a ARP crank bolt i will use. My question is, can i replace this seal without removing anything if i do it from the bottom? Will a seal puller from one of the autostores (autozone, Oreillys) work to pull the seal without removing the timing cover?
Old 03-18-2011, 11:25 PM
RARON455's Avatar
Yes a puller will work, Once you get the balancer off you can slide the puller in behind it and remove it.
Quick Reply: Replacing front crank seal
