hesitate to accelerate?
Old 03-18-2011, 10:04 PM
323steel36's Avatar
Default hesitate to accelerate?
Help my car hesitates to accelarate when I punch it. Only when the car
has been on traffic and i try to punch, my car hesitates to accelerate. No
engine light is on? What could it be? 93 trans am A4 auto 108,000 miles.
When i accelerate normal or slowly it works fine, but when i punch it, it
hesitates and goes but it feels like its going to turn off and then goes?
PLease help!!!!!!!!!!!!!!
Old 03-18-2011, 11:31 PM
z28DC's Avatar
Are you hitting the rev limiter? my car does this at speeds under 30.
Old 03-19-2011, 02:35 PM
323steel36's Avatar
Its an auto so i cant hit the rev limiter unless i drop it to first and play with
it. Most of the times i leave it in overdrive(4th gear). I can only feel it when
there car has ran for a while and i try to punch it and it hesitates real
bad.Say im going 65 on the freeway, and then i punch it, it feels like it wants
to turn off and then goes and then it hesitates again, but when i accelerate
normal it works fine. My fans turn on, it has a new water pump, and a new
radiator, idk it feels like it looses power?
Old 03-19-2011, 02:58 PM
greenlanternws6's Avatar
I bet it going to be you cap and rotor.. I had the same problem with mine .. I replaced eveything then when it came to the opti my cap was the problem .. Take off the opti and check the cap..
Old 03-19-2011, 03:16 PM
that or can be you maf going bad as well..
Old 03-19-2011, 04:41 PM
323steel36's Avatar
Yeah i think your right. What would i look for when i take off the cap? Could it be just the cap or the whole opti?
If it is just the cap, do i just buy the cap and rotor kit?
As for the maf sensor, it doesnt have one since its an 93 speed density.
Old 03-19-2011, 05:14 PM
96TransAmboosted's Avatar
look at the terminals and the rotor tip and see what color they are, this will tell you
Old 03-19-2011, 06:14 PM
323steel36's Avatar
ok il check that out. If by any chance it is the whoel unit. what do you guys think about this unit? It seems more than decently made? Plus it isnt 300+?
http://cgi.ebay.com/ebaymotors/ws/eB...m=220445253720
Old 03-19-2011, 07:19 PM
rbaksi's Avatar
Yes I have that one and it works well. Others will likely tell you ACDelco but those are around 300. I've ran a chandler motorsports opti for 3 years now and its worked great.
Old 03-20-2011, 01:43 AM
323steel36's Avatar
Thanks bro ima go buy this one. do you know what warranty it came with?
Old 03-20-2011, 10:12 AM
Ill just say that autozone also has one for a decent price and has a lifetime warranty so no matter what happens they will swap it out. I have used one for over 4yrs no problems. Im not sure if that unit comes with the cap and rotor but if it does thats a crazy cheap price, and if you do have issues with it you only have 30 day warranty, vs a life time just saying.
Old 03-20-2011, 02:00 PM
323steel36's Avatar
Which one has 30 day warranty? The autozone is the one you have used for 4 years? If i do need to change the opti what would I also have to change the spark plug wires connected to the opti? which wires do i get?
Old 03-20-2011, 06:18 PM
The brand new one from the zone is life time, get msd wires and cap and rotor kit. wires are 109 and cap/rotor kit 149
Old 03-20-2011, 06:48 PM
95chevyz28's Avatar
i think merv once said that he used the duralast brand at autozone with no problems before. Correct me if im wrong. They are like 40 bucks.
Old 03-20-2011, 07:19 PM
Whats 40 bucks? am i not reading your post right or something but what did the MERV buy and have good luck with?
Old 03-20-2011, 09:14 PM
95chevyz28's Avatar
autozones wires...the duralast brand. I think they are around 40 dollars.
Old 03-21-2011, 07:34 AM
ok thanks for clearing that up. i hate those ones cause when they heat up they dont fire as good, there cheap and if you try and pull a plug when its kinda warm the boot will just slip right off the wire
Old 03-21-2011, 09:30 AM
tricked94camaro's Avatar
yeah do plugs in wires first. just had that problem.
Old 03-22-2011, 12:07 AM
323steel36's Avatar
Check this out. The wire fconnected from the opti to the igntion coil had two slitts. It was not fully slit, but could this be a problem
Old 03-22-2011, 01:30 AM
95chevyz28's Avatar
its possible. I would definetely change that wire out.
Quick Reply: hesitate to accelerate?
