oil pressure to high???
Old 03-20-2011, 12:24 PM
Drak03's Avatar
Default oil pressure to high???
I have a 94 camaro, I put in a new 180 degree thermostat and changed valve cover gaskets. And now it idles around 40psi and at WOT around 70. Im guessing this isn't normal at all, or is my oil pressure gauge just acting weird. It read fine before I did this work. Only mods are exhaust and trans work
Old 03-20-2011, 01:08 PM
Drak03's Avatar
Bump. Anyone?
Old 03-20-2011, 01:17 PM
RamAir95TA's Avatar
What was the oil pressure prior to your fixes?
Old 03-20-2011, 01:22 PM
Drak03's Avatar
Like 10 psi, and 30 at WOT. I don't see how any of the things I changed would make that much of a difference. Oh and I changed the PCV valve hose that goes from the valve cover to the throttle body
Old 03-20-2011, 03:27 PM
rbaksi's Avatar
10 at idle was way too low. It should have been higher, at least 30. Did you change your oil with a different type or weight?
Old 03-20-2011, 05:48 PM
Drak03's Avatar
No I use the same oil every time, it was changed about 500 miles ago
Old 03-20-2011, 06:03 PM
ivan_key's Avatar
All my lt1 cars only ran 10 psi at idle as well
Old 03-20-2011, 06:39 PM
rich5368's Avatar
Cold mine idles at around 50-60 and hot it idles around 20 and 45-50 WOT.
Old 03-20-2011, 06:42 PM
95chevyz28's Avatar
mines about the same...cold start about 70. warm idle about 40. Warm driving about 60. I have a freshly rebuilt motor though.
Old 03-20-2011, 07:57 PM
lttransam's Avatar
shoot mine used to go to 85ish when it was cold at part throttle, but once warmed up it would go down and idle about 40.
Old 03-20-2011, 08:28 PM
RamAir95TA's Avatar
Get a mechanical gauge on there to verify your actual pressure. There's a chance you maybe bumped the sensor, broke the wiring, etc.
Old 03-20-2011, 10:37 PM
lttransam's Avatar
yep after breaking mine i put a mechanical gauge in and never looked back.
Old 03-21-2011, 12:53 AM
Drak03's Avatar
Ok cool thanks. Gonna pick up a set of gauges soon
Old 03-21-2011, 04:25 AM
fex77k's Avatar
10psi per 1000 rpms is within GM specs.
