Cam/bolt on + nitrous guys....
Old 03-20-2011, 12:34 PM
trilkb's Avatar
Default Cam/bolt on + nitrous guys....
This has probably been answered befor, i did a search and maybe i just searched for the wrong thing.
Does anyone have a cam only car with stock bottom end and a shot? Im curious as to what the heads can take and what the block can take. There are alot of cam only cars, and alot of nitrous only cars. How much are you stressing the limits of the stock bottom end by doing a cam plus say a 75-125shot of nitrous? im thinking just a 100 shot. A cam should put a lt1 into the ballpark range of 330rwhp give or take 10-15hp with stock heads. I beleive nitrous only cars have put down around 400rwhp? if im wrong let me know.
I was happy with the direction my car was heading, and its actually close to being back together now . Im wondering what numbers people are doing, dyno and track times, with a cam only car + a small shot. If you have time slips or dyno numbers that would be great, also maybe a "reliability" report would be nice, just wondering how safe it is.
Thanks guys..
Old 03-20-2011, 12:36 PM
robsquikz28's Avatar
I have seen 10 second time slips from people with cam only nitrous cars...Its possible but with more than a 100 shot
Old 03-20-2011, 01:54 PM
TwoFast4Lv's Avatar
My car back in 2000 went mid 11s in full street car attire with a cam and a 75 shot Justa little 211/218 LPE cam at that
Old 03-20-2011, 01:59 PM
gregrob's Avatar
Baby cam and nitrous 11.58 @ 121 7600 DA
Would have been easy 10s at sea level with a decent 60
Old 03-20-2011, 02:00 PM
gregrob's Avatar
Thats a full weight 6 speed
Old 03-20-2011, 02:41 PM
jasonisdn's Avatar
my old stock block was taking 125 dry with extra psi on the fuel system. it was afr head with a small cam. i never got it to the track before i took it out too rebuild. when we were tuning it i believe it was making 430's to the ground. that was many years ago though.
Old 03-20-2011, 02:45 PM
trilkb's Avatar
cool. Im thinking about a 100 shot with my build now. sounds like everyone has had great results. Makes me wonder why more people dont do a cam and a small shot, it sounds like it works well.
No blown motors from this i take it guys? assuming everything is set up properly?
Old 03-20-2011, 02:53 PM
nitrous2fast's Avatar
most people are scared of nitrous. bad rap from movies and dumb people....
the stock rods can hold ~500 hp don't be afraid to make some hp. The only draw back on nitrous is what the pistons can hold. There are a few running crazy amounts of N20 but those are exceptions and not the rule.
I wouldn't be afraid to run a 380 rwhp motor and a 150 shot. Precise tuning is required
Old 03-20-2011, 04:20 PM
greenZ96's Avatar
Ive got a 125 shot on a stock bottom end cammed car. 170xxx miles on it too. No track times though.
Old 03-20-2011, 05:13 PM
green94z's Avatar
My cam only stock longblock plus 200 shot was running 6.7s in the 1/8. Also had stock 10 bolt and cpt built trans. could have probally gone faster just didnt want to break the 10 bolt
Old 03-20-2011, 05:51 PM
AZ2ENVY's Avatar
Im running a 200 Shot with Heads , Cam , Full bolt ons , Drivetrain , Full Suspension , Fuel
System , Tune , etc . No times yet but the only problems Ive had were blown 60Es and 10 bolts . Bottom end is holding for now .
Old 03-20-2011, 07:53 PM
IrocZ's Avatar
Stock bottom end cam and 150 shot and its gone as fast as 11.2 at 121. Getting ready to put a k member on it and the heads I've had for 6 years on it
Old 03-20-2011, 08:11 PM
airfix's Avatar
In the next month or two I'll be making som passes in my new set up. Car made 391rwhp since then I've put a bigger cam in it and I plan on spraying a 125shot. The cars set up for drag racing ie weight reduction all tubular suspension, k member drag brakes crap like that. I'm hoping for alteast high 10's once the cars dialed in and I get some practice on the track.
Old 03-20-2011, 08:23 PM
trilkb's Avatar
sounds cool people, im really just looking for stock head cars though with cam only and nitrous. not head/cam nitrous cars. Some of these cars sound pretty nasty especially IrocZ's set up. Your on stock heads im assuming right?
Old 03-20-2011, 10:30 PM
CamaroRacing12's Avatar
in the future. i plan on getting 10's nitrous and bolt ons only, stock cam. from what i have seen these motors can take a 125 shot safely on a reg basis and i have seen some throw upwards of a 200-250 shot at them and last multiple seasons.
Old 03-20-2011, 10:35 PM
boostedlt1's Avatar
when you gonna run it?
Old 03-20-2011, 11:09 PM
AZ2ENVY's Avatar
Im gonna run it before I put on my new AI 200cc heads and after
Expecting mid 10's with the new setup
Old 03-21-2011, 01:16 AM
how are you blowing up parts if you havent taken it to the track yet??? Street use only?
Slicks or D.R
Old 03-21-2011, 10:24 AM
IrocZ's Avatar
Nothing that nasty about it, has a smallish cam 224/236. A Nx wet kit with a window switch and tps switch, built tranny and vig stall, and just about all the supporting bolt ons. It has some normal weight reduction done to it. Back seats gone, spare and jack gone, sway bar, a/c, and has pro stars on it. All that is counteracted by the heavy cat back and my fat *** in the car.
Old 03-21-2011, 11:53 AM
AZ2ENVY's Avatar
Slicks or D.R
Ive had it to the track . I ran an 11.6 at 6000 ft elevation . That was on a way smaller setup
than what i have now . I started breaking parts with slicks then it snowballed into **** poor
trans builds so its kept me from the track for a while . The car is ready to go again so let's
hope it dont break
Edit: cant forget about the converter failures as well . I got sucked up into the Fuddle, CPT, etc. **** so that didnt help either . Ive had alot of drivetrain problems haha
Quick Reply: Cam/bolt on + nitrous guys....
