Have a quick question about LS6 intake
On the back of the LS6 intake, there is the MAP sensor, brake booster and a vacuum line. Where does the vacuum line come from? It goes to HVAC but what is that? and where is the other end of that line go?
Also, on the drivers side of the engine, valve cover, there is what appears to be a crank case ventilation hole back close to the firewall side of the valve cover....where does that vacuum line run to?
Thanks
Thanks
Ok thanks man. In reading more, I believe they are both capped also.
Anyone with a stock manifold (LS6) that can take a peek behind to ensure the HVAC port is indeed plugged, I would certainly appreciate that.
