What is this on the end of my fuel rail?
Old 03-21-2011, 10:02 AM
cleb's Avatar
Default What is this on the end of my fuel rail?
I didn't really notice it until I got my fuel rail covers because it keeps the driver side FRC from snapping down on the fuel rail. Anyway what is it? What is it called? How do I get rid of it? Thanks!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 03-21-2011, 10:46 AM
Mereniuk's Avatar
Looks like a Hobbs switch.. (pressure switch) just take it off and put a plug on the end of the rail?
Old 03-21-2011, 10:58 AM
91sbcamaro's Avatar
Originally Posted by cleb
[IMG][/IMG]
[/IMG]
Is that a hole in the side of your intake?
Old 03-21-2011, 11:00 AM
Taspeed's Avatar
yeah..looks like part of an electric fuel pressure switch
Old 03-21-2011, 12:27 PM
Pocket's Avatar
+1 for fuel pressure gauge sender
To delete you need a schrader valve to screw back into the rail, then a cap. Salvage one off a spare rail or rob a V6 from a JY
Old 03-21-2011, 01:08 PM
Z284U2TRY's Avatar
that is a fpss fuel pressure safety switch. It is mainly used in nitrous applications. The n20 maybe the cause of the hole in the intake.
Old 03-21-2011, 10:33 PM
Mike 02T/A's Avatar
Looks just like mine!
Someone had spray on the car before the OP bought it.
Old 03-22-2011, 03:46 AM
cleb's Avatar
So can I get a "schader valve" from a parts store? And yeah I didn't know the car had been sprayed when I bought the car. I didn't know **** about nitrous, or cars in general when I bought my car 2 years ago. But thanks to everyone on ls1tech I'm becoming less retarded by the day. Thanks again!
Old 03-22-2011, 03:59 AM
cleb's Avatar
There is one just like it on the other side. I don't know why they are there, but it is an ls6 intake if that matters at all. They don't actually open up to the inside of the intake, I think I would have some problems if they did.
Old 03-22-2011, 08:42 AM
bayer-z28's Avatar
OP: look for a schrader valve "core tool" to re-install it. I looks like a female flathead screwdriver.
The core tool is also handy for fukin with people when they **** you off. De-core their tires and put the caps back on.
Old 03-23-2011, 04:27 PM
cleb's Avatar
So is the schader valve like the same thing as a tire valve stem core, or is it totally different?
Old 03-23-2011, 07:15 PM
Ollie8974's Avatar
Yes, they look like a tire valve. But don't use a tire valve in there. A Schreadar valve is designed for high pressure. A tire valve is not.
