slightly rough idle, slight hesitation
Old 03-21-2011, 12:00 PM
LT1Air's Avatar
Default slightly rough idle, slight hesitation
This is an intermittent problem. It just started today. At idle, the car will drop the rpms around 600-750. Then when im driving it, it kind of hesitates during acceleration. Then sometimes it wont happen at all. I just intalled at B&M ripper shifter. Is it possible that the shifter isn't fully allowing the trans go in and out of gear fully?
Old 03-21-2011, 01:58 PM
96azz28's Avatar
Check for vaccum leaks mine would idle low.
Quick Reply: slightly rough idle, slight hesitation
