M6 4:11 guys wanted to answer
Hey Guys im tring to figure out the best tire size ... for my setup .....car is makin 400hp at the wheels .. I have 2000 camro with 4:11 m6 and a mS3 Cam making peak power at 6300rpm ... what size tire are yous with the same or similar setup running and at what rpm are you crossinjg the line in the 1/4 mile.....
http://www.f-body.org/gears/ that sould help you out
If you don't already know, figure your tire size based on trapping in 4th gear (1:1 ratio).
Are you running a 9"? It has been my experience that the GM & Dana's only accept 4.10's.
4.11's makes sense then. I won't be set up for the track for another month or so. I will be running the 1/8 mile and I have a lead on a 1/4 mile track that may let me run the 1/4 without a roll bar. If I have to go to a sanctioned track, I will need a cage which will probably be a while.
My plans are to run a 26" tall tire which will be 128 mph at 6800 in 4th gear. That should be just about right in the 1/4 mile. If I need to, I could go to a 28" which would be 138 mph. That gap will leave me room for improvement just by changing tire o.d.
I have the same cam, m6, I had 4.10's (now I have a moser 12 bolt with 4.11's) and on a 26" tire I am going through the traps at the top of 4th. Motor and nitrous....on the bottle I am going through the traps in 4th around 6800rpms.
all motor I also make 400rwhp on my nitrous tune....so our cars are as close as they are going to get.
