AFR225's
AFR225's
What kind of results should i expect with a set of AFR225's on top of my 383 ls1? They are milled to 59cc and my compression will be about 12to1. I do not have cam specs but it will be aggressive (as big as i can go that Pat G will suggest). I just read that a guy with PRC 2.5 heads got some good numbers on a mustang dyno. I have an A4 with 3600 stall and 10 bolt at the moment.
yes, all supporting mods, sorry forgot to add that stuff, going to have duel cutouts are the headers instead of at the Y where i have it now. how are people getting 480+ i wonder?
I made 463hp 414tq with afr 205 heads on a 346ci ls1,m6 car. Also,i was on a mustang dyno that i lost 25hp on when i went to it from a dynojet. You with the RIGHT set up should get 450hp to 460-ish-hp. Match your intake,cam and heads and you will have a fast car.
I made 470 hp/ 440 TQ , with old LPE 243's heads, FAST 90 unported, 23x/24x cam. Tune was suspect though as far as timing.
You should be somewhere in the 450-480 range easy.
You should send the heads to Tony and let him work his magic on them. Take a look at my sig. I made 484/412 threw cats with a 346 and afr 205's and supporting bolt on's.
