Maintenance being done this weekend
Getting ready to do the trans fluid change on my trans am and I was wondering if it was ok to refill my fluid through the dipstick tube under the hood...
Car ha 90k miles just wanna do a little maintenance
Thanks
Thanks
Want to make life a lot easier and less messy? Buy a vacuum pump fluid changer. You suck all the fluid out of the pan before dropping it and eliminate juggling a pan full of fluid and the resulting flood of ATF.
Also helps with differentials, oil changes on power equipment (generators, lawn mowers, etc.)
If you change the fluid in the pan regularly you don't need a flush.
