97 LS-1 Corvette heads question
Old 02-26-2003, 06:26 PM
kilawhite98's Avatar
Default 97 LS-1 Corvette heads question
I came across a good deal on some 97 corvette heads for my 2002 LS-1 motor. I want to have some heads ported and was wondering if it would be better to work the 02 heads or the 97 ones. I just want to make sure that I will not run into any problems if I decide to port the 97 heads. I am new to this so any opinions please. If I sent heads off to be worked will most places core exchange different years?
Old 02-26-2003, 07:10 PM
LS1derfull's Avatar
Default Re: 97 LS-1 Corvette heads question
97 heads use different valve covers and coil pack holder arrangements. 97 castings dont flow as well as 2002 for several reasons. I would port your 02 castings or get a core set of 2000+ castings to work.
Old 02-26-2003, 10:43 PM
slow's Avatar
call the shop about the core issue, some have a $900 on 97-98 heads, and $600 on the newer heads.
They might be willing to swap them even, send you newer ones for some 97 cores,
Ryan.
