Dual 190lph for single turbo 6.0L?
Old 03-22-2011, 07:17 AM
4Birdman's Avatar
Default Dual 190lph for single turbo 6.0L?
Trying to figure out a cost effective way to set up my fuel system. I'm currently running a Walbro 190lph pump, and I am in the process of swapping in a 70mm turbo on a mild 6.0L.
I'm going to run some 62lb injectors, so I'm trying to figure out what to do with the fuel pump setup. I think a dual 255 would be overkill for this setup, so I'm thinking I could get another 190lph one and dual them up. Would save money that way, and I think dual 190s would be enough for my setup.
What do you think?
Old 03-22-2011, 08:29 AM
wkdivr's Avatar
No need for a huge Magnafuel, or Weldon, but "cost effective" on the fuel system is usually a problem. Look at the Lonnies/Racetronix systems, they're trouble free, and for the price, I'd say, excellent. "Saving money" now.......................will usually cost you money later.
Old 03-22-2011, 01:27 PM
Pocket's Avatar
255 primary, 190 secondary off your hobbs switch
Old 03-22-2011, 02:15 PM
4Birdman's Avatar
I'd be saving money by not buying two pumps, I've already got a good 190lph pump. Saving money by buying a piece of **** I would agree with you, but this is not the same.
