Western Members CA, AZ, NV, UT, CO, NM, HI
Has anyone in Colorado?
Old 03-22-2011, 07:27 PM
01transampower's Avatar
Default Has anyone in Colorado?
I have an 01' T/A. I was thinking about pulling off my air system. Is that possible with being able to still pass emissions or no? Car will run better and less weight.
Old 03-22-2011, 07:41 PM
ZexGX's Avatar
Not sure how the car will run better. Not like it really hurts performance. It's just an extra 15lbs of dead weight, so that's like 1 horsepower gain? It hooks up to the exhaust to heat up the cats faster on cold starts so they work more efficiently. It doesn't re-route used air back into the engine like EGR does.
Old 03-22-2011, 07:57 PM
So big question would I still pass emissions? I dont have egr. So itd be cool if I could get away with taking it off.
Old 03-22-2011, 07:58 PM
tpunk's Avatar
Yeah, but some states still have visual inspections and you would fail without it. So I guess the question is do they have strict visuals in CO? If the car is warmed up before a sniffer test the sniffer wouldn't detect the difference to fail you on.
Old 03-22-2011, 08:14 PM
They only look if it has a hard time passing or if it doesnt pass. Thats it.
Old 03-25-2011, 04:36 PM
tpunk's Avatar
You're good then. All the air pump is for is to get the cats to light off quicker on initial start up. If you drive the car there it will already be up to temp and have no effect on the reading.
Quick Reply: Has anyone in Colorado?
