No Oil Pressure?
No Oil Pressure?
I just got my motor in the car and i had oil pressure for like 1 min. Then all the sudden it doesnt have oil pressure no more. So what could be the problem?
I'd first check for a broken oil pressure sensor. If its intact, then it has to be an internal problem. If you take the timing cover off and the oil pump pick-up tube o-ring looks good, then I would check for objects in the oil pan.
Was the oil pump replaced? Removed? New O-ring installed?
If your gauge is broken, you could always try removing the oil filter, putting a bucket under there, and turn it over very briefly. If oil comes spewing out, you have pressure.
the motor was rebuilt at a machine shop and just used new bearings and rings and new oil pump...and a new tsp 231/237 cam and a new o-ring was installed on the oil pump as far as i know..
I got a question? I took off everything and the o ring on the pick up tube is still there? So? When it was installed could it just have been on in some messed up way? Or is the problem something else.
i'd say it's probalby somewhere else. usually even if the o-ring is totally missing there will still be a little oil pressure (like 10lbs.). posibly a broken oil presure sending unit? that's what i would try next.
I figured it out! The valve release was fkin clogged full of bs.. the d/as that built my motor put some kind of lubrication in the oil pump and it was all in the valve relase. It was like gluey and thats y i t aint pumpin. I called Joesph at TSP he helped me out big time. I owe my life to them.
