Dynoed setup power seems low/Update tune posted
Engine Is 6.0 flat top pistons L92 heads with light clean up and milled 25 thousandths with stock ls3 head gaskets ,Ls3 intake ,long tubes and GM hot cam.And before we start bashing the hot cam I did my research and I know there are a lot of other cams but the hot cam fits my needs.
Should this combo be making more or does the power look good
Car
Car is an auto T/A with 323 gear custom cold air intake exhaust is long tubes 3inch y pipe over axle into slp loudmouth and dumped.Car is speed density so no maf
That's basically what a bolt on 364 should make. You have better heads/intake a bigger cam, so there's no reason why you shouldn't make more power.
I would also question the intake tube and filter, as unless there is a mechanical problem with the engine that seems to be the only sub-par part.
What sort of MAP and IATs are you seeing on the dyno?
set-up
Iat's were show between 70-80 and the map readings showed that there is no restriction in airway.The engine has 611 miles it is completely fresh.Trying to get the tuner to send me the tune so I can post to see if people see any issues because this set up make almost the same power as my 6.0 with ported heads intake and full exhaust
