T5 5th gear set interchangability?
Are any stock 5th gear sets available to get a 5th gear OD in the 0.8 - 0.85 range on a NWC 82-87 camaro V8 T5? Will any S10, astro van 5th gear combos work?
I found aftermarket gears for WC, but I need to keep a mechanical speedo from the NWC.
I do a lot of T5s but not many older NWC Gm units. I don't know right off the top of my head what gears you could use with a 2.95 ratio unit to get you where you want to be. I know there is an after market Ford kit that gives you a .80 od but doubt there is a similiar kit for the GM units since there are far less of them out there.
.74 is pretty damn close to where you want to be. I would adjust the rear end ratio or tire size to get it exactly where you want to be in 5th gear if its that critical.
I realize the T5 is not the strongest trans, and the 1st overall isn't great. But I can probably find a camaro V8, 82-87 pretty cheap, go through it and was hoping to swap out the 5th gear. This is going in a 72 442 with a 5.3.
Finding a 0.8 OD is tough. I've got a Richmond 6 speed behind a 6.0 in my corvette, which is great since you can pick the 6th from about a dozen gears. But that's not in the budget.
A TKO will require cutting the tunnel in my 72 442, that wont fly.
So without rebuilding a newly rebuilt rear, I was hoping a T5 with a gear swap would be ok for a hiway cruiser behind a 5.3 in the Olds. No racing....
$300 for a used V8 T5, $50 for a set of used 5th gears, $125 for a rebuild kit fits the budget.
