Tools & Fabrication - found a cheap simple way to fill the transmission
VETTEX2
03-24-2011, 02:22 PM
http://www.sprayco.com/images/R32.jpg
http://www.amazon.com/Sprayco-Long-Reach-Plant-Waterer/dp/B000VYGCZW
works on an C5 Corvette A4
I'm thinking it should work on a manual
I just used a heat gun to make the tube bend the way I needed it so it would fit.
I doubt it would work with 90wt but dexron flows easily and it worked to perfection
found one at a local hardware store for 4 bucks
FYI : the tube goes to the bottom so you just squeeze it to make it work
HOLDS 2 QTS.
NeedaV8foundation
03-24-2011, 02:31 PM
works on an A4
HOLDS 2 QTS.
they make a pump that attaches to the quart bottles the fluid comes in and you just use the hand pump instead of squeezing the bottle. they are made for outboard boat engines. it seems like a better idea.
VETTEX2
03-24-2011, 02:41 PM
been there , done that
this is easier
you can do it with one hand
I have various types of pumps and found this to be the least amount of hassle
for 4 bucks and a few minutes with a heat gun , give it a try
I bet you end up liking it , and for a vette A4 it's by far the easiest
Jon5212
03-24-2011, 03:35 PM
On my T-56 Camaro I just filled it through the shifter :)
Cronic_Moronic
03-24-2011, 08:09 PM
You can't shove a funnel into the dipstick tube?
VETTEX2
03-24-2011, 08:55 PM
not on a C5 and newer Vette
GoatPilot87
03-27-2011, 11:09 AM
Agreed. Go to Wal-Mart, look in the oil aisle, and where the marine section is buy the little screw on pump for a couple bucks. Works great, nothing else, required, and takes up very little space.
VETTEX2
03-28-2011, 09:32 AM
trust me , this is easier
ToplessTexan
10-09-2011, 05:19 PM
Can you squeeze it in fast enough?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
