T-56 AfterMarket Or Modded Slave Cylinder???
Old 03-24-2011, 03:25 PM
LSWNDR's Avatar
Default T-56 AfterMarket Or Modded Slave Cylinder???
So as most of you know already the tick unit replaces the stock master for butter feeling shifts at WOT, but what do we do about the slave cylinder at WOT because mine just went out after a month of having it installed in the car. When i called tick performance joey the awesome man that he is said that the ACDelco **** is junk an changed the designed so they just went back with selling the stock Gm Replacement ones again since they stuck with the older design that didn't seem to have changed. So i bought one of the slave/throwout bearing kits for 159.00 an i'm just waiting to get it on the rack to get it installed to see the final results an personal enjoyment of WOT shifting my 408 an revving it the moon without having clutch disengagement problems. Does anybody in the history of t-56 mod parts an manufactures make or do anything to the ensure that the slave can handle high RPMs without leaking???
Old 03-24-2011, 04:12 PM
sabastian458's Avatar
Punctuation my friend. Makes for an easier read.
McLeod makes an aftermarket slave I think*.
Old 03-24-2011, 04:14 PM
Jeff Smith's Avatar
do search here.Some posts have good information.
Old 03-25-2011, 10:12 PM
snake charmer's Avatar
there is a variety of add ons i have seen on the web . as far as being documented on what they do is a bit grey , independent documentation is where some research would come in . most that i read buy a stocker and run it till there is a problem and then to replace it is a chore .
that said tick has an excellent reputation with their product and support .
cheers
Old 03-26-2011, 12:25 AM
SS#2906's Avatar
I am very pleased with the hydraulic unit that RAM offers. I haven't really got on the car since I just recently installed this along with the Tick Master, but so far it seems to be holding really good.
http://www.ramclutches.com/Products/...se_bearing.htm
Old 03-26-2011, 05:34 AM
Z500HP's Avatar
So with all the aftermarket parts for a built trans we are stuck using a oem slave? That sucks!
Old 03-29-2011, 05:33 PM
cleb's Avatar
There is no need for an aftermarket slave because the GM slave works fine. "If it ain't broke don't fix it."
Old 03-31-2011, 10:26 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Agreed. The problem with the stock hydraulic system is the master - we actually designed our Adjustable Master kit to work with the stock GM Slave & TOB.
Old 04-01-2011, 12:49 PM
LSWNDR's Avatar
Yeah i know joey an the master makes high horsepower cars WOT shift like they should with your kit that i have installed an it's super ******* sweet it's just a shame that their isn't any after market slave mods yet... ;(
Old 04-08-2011, 01:53 AM
Z500HP's Avatar
well I have the mcleod rxt clutch and just dont want issues. Mcleod does have a slave but its like $400 I think.
Quick Reply: T-56 AfterMarket Or Modded Slave Cylinder???
