Guesses on gains from fuel system upgrade?
Had my car dyno tuned a while back made 313/331 with just catback and lid but around 3500 it started losing fuel pressure and flattening out and I found out it had a leaking injector.
Since then I've replaced the fuel pump and put some fuel injectors that the tuner suggested would make a small difference in power as well as deleted the emissions.
So my question is how much more power should a catback and lid car make with proper fuel pressure and do you think the injectors will change much?
Car is a m6 and it dropped to almost 20psi before the pull was over
I wasn't saying he was gonna hit 350 im just saying I have seveal friends with ls1's with similar mods making power between those numbers.
And it was dynoed on a Dyno jet.
