Lq9 build
Lq9 build
Would just like some input on my first ls build i have a lq4 block and crank stock ls floating pin rods and stock flat top pistons. Have 317 heads that i am porting and going to get milled .015" with comp cams 918 springs. stock intake and a tsp 224r cam. Will have a 4l80e trans with around 3k stall. I am swapping this in my obs ext cad 2wd. How much power do you think this setup will make? i do not have the pistons or the cam yet would you change anything. Plan to n/a.
