Tools & Fabrication - Need bolts for engine on engine stand
Billiumss
03-26-2011, 08:32 AM
Hi Guys,
I am going to be putting a LS engine on a engine stand but what bolts do I use?
What size and grade?
Thanks,
Bill
Billiumss
03-30-2011, 03:32 PM
Either no one has never put a LS engine on a engine stand before or this is the wrong section to get answers???
Oldsmobility85
03-30-2011, 10:59 PM
I have some bolts in my toolbox ill measure up for you tomorrow evening. I think they are 10mmx1.5 but not positive. I am pretty sure though.
Rubrburnr
03-31-2011, 12:00 PM
I believe they are 100mm long as well....
bww3588
04-05-2011, 06:10 PM
M10X1.5
i got them about 3 inches long and stacked up washers to make up the difference. i didnt feel like buying 3 different lengths of 4 bolts, so i just bought them long and found some washers in the tool box.
01ssreda4
04-07-2011, 12:14 AM
You use the size/type of the bellhousing bolts. I measured a bellhousing bolt length, then measured the round collar length on the mounting points of the engine stand, added the 2 measurements together, then went and bought bolts as close to that length as possible from Home Depot. Get the best grade they have available.
