2001 4l80e to 2006 lq4 - crank spacer?
I don't quite know what to do at this point. I bought a used lq4 from an 06 silverado to put into my 68 camaro. I've replaced the cam and heads. I also bought a 4l80e (1hpp) from a 2001 GMC van with a 5.7l engine. everything seems to be fine except when I bolt the engine and trans together the flex plate is about a half inch away from the bolt holes on the converter.
I thought that I might need the crank spacer and longer bolts, but when I pulled off the flex plate it looks like this:
Maybe I'm retarded but isn't that a crank spacer? It seems like its either that or part of the flex plate...
How do I make the trans fit??
You heard wrong
Only 99-00 iron headed 6.0's have the longer cranks. If you have alum heads on your 6.0 regardless of year, it requires the spacer with a 4L80E or older auto trans. Your 01 has the spacer as you can see, do not loose the longer crank bolts, they are required to make the spacer fit
I spent hours researching this a while back - I am putting an older 4L60 behing an LQ9.
The 6.0s are different - the Lq4s were in different vehicles and had different transmissions than the LQ9s so there are flat flexplates and curved flexplates. My LQ9 happens to have a curved flexplate so I need the spacer.
Some of these LQ4s had a stock spacer from the factory. I was there the day my LQ9 was pulled and no spacer.
Had the same flexplate behind my 2005 LQ-4 with a 4L80E. I am using it for the 5.3 I am rebuilding an putting a TH-350 behind it for my Tool supplier. We are putting it all in his 70' Nova. Nice to have without the added expence. Seeing as I am using a T-56 behind the LQ-4 in my S-10.
Spacer removal lq4
oct03gto hasn't been here for over 4 years. Check post dates....
