window motors
LS1Tech Administrator
Received 1,462 Likes
Here is a great write-up:
http://shbox.com/page/windowmotor.html
It's not a hard job. It should probably take 1-2 hours if you've never done this before.
I get replacement motors at AutoZone. Dorman brand, they seem to be great.
1 Post
Gotta have some tools not everyone might have if i recall though..
Hey RMP was meaning to ask you bout those motors, why not the ones of carwholesale or w/e from ebay? And how often do you use your windows? I'm at a toss up between both of those and don't know which will hold up longer, maybe there both the same though.
Some people seem to burn motors out pretty often (GM or aftermarket), I think it might be due to the extra drag of tinting paper that many have on their side windows. All I can tell you is, I have no tints, and my stock driver's side motor lasted until 95k miles (and the passenger one is still working OK), so I expect and hope that the Dorman will last a long time as well.
Ya mine are tinted also and I have 915xx miles. They still work but are kinda slow. And my drivers side window up at the corner leaves a gap sometimes and the wind noise sucks...new motors fix this?
Welcome to the F-body my friend. Lol. Some say its easy, and some say it a bitch, after you do it twenty times (and you WILL do it a few times!) you wont have any issue. MAKE SURE you buys the ones with LIFETIME warranty so when they go out again you can just ****** them out swap them for a new one. IDK why but nobody makes one that lasts? Maybe its just the weight of the glass, and the aftermarket are constricted to factory designs due to patents or something but iy wont be the last ones you out in. IF you rivet them go a bit oversize so they dont walk, and go to Harbor Freight and buy pneumatic riveter if you have acces to an air tank. If not, find some bolts, nuts, and washers and put them in. There are some good threads on here as stated above to help ya' out man.
RPM I'm still new and the driver's door on the car I bought doesn't go down/up. I went to autozone's website and wanted to know which Dorman motor you buy because they had a couple. Or are any of them good?
I did not buy the regulator, just the motor only.
As for the rivet gun, I would skip that. I just used bolts, much easier IMO. Only time you need to use rivets is to replace the regulator.
